what should i expect to pay for a tune?
Old 03-07-2009, 06:29 PM
synisterC5's Avatar
Default what should i expect to pay for a tune?
I live in the detroit area and i'm finishing a H/C project on a 99 FRC. car has full bolt-ons as well. what should i expect to pay for a tune, never built a f/i car before and i dont need to be ripped off!
Thanx
Old 03-07-2009, 06:31 PM
shtnfrds's Avatar
dyno or street tune.
I was quoted anywhere from 300-600 for a dyno tune on a stock motor with simple bolt ons if that helps you at all.
Old 03-07-2009, 07:21 PM
synisterC5's Avatar
well not sure if i need a dyno or a street tune. im putting in a torquer v.2 and 5.3 heads, should get me 11.5:1 comp. i'm on a tight budget so if a street tune works and is cheaper i would consider it, however i dont want to have to do it twice to get it right if ya know what i mean
Old 03-07-2009, 07:28 PM
Administrator
unit213's Avatar
Somewhere around $500...give or take a little.
Old 03-07-2009, 08:09 PM
highflyin's Avatar
I paid 500 for a dyno tune before i ended up just buying hp tuners to do it myself.
Old 03-07-2009, 10:31 PM
jocko's Avatar
where are you dude?i got a similar set up on my frc and i got hp tuner.
Old 03-07-2009, 11:00 PM
AutomagicLS1's Avatar
Make sure ya give them a list of things you WANT done. If you just show up at say I need a tune it appears most guys that post up their professional tunes on here just have hacked PE tables. Make sure you tell them you want idle,drivability (fuel economy), timing adjusted, VE/MAF tables right, trans tables tweaked if your an auto and so on. OR you could just spend the money that you would on a tune and just buy HP tuners or efi live and do it yourself
Old 03-08-2009, 12:58 AM
synisterC5's Avatar
so how difficult would it be to use hp tuners, can i easily hurt the engine and what is the cast. know i can get the tuner for $500 but do i need wideband o2 as well?
Old 03-08-2009, 01:16 AM
MikeD101898's Avatar
Pay someone who knows what they're doing to tune it. Do some research around your area on who is the best around. It's not worth saving the couple extra bucks to mess up what you've already poured so much money into, or not getting the most potential out of your setup.
