Engine Gurus Come In - SCR, quench, pump gas question
Old 03-08-2009, 06:41 PM
quadman's Avatar
Default Engine Gurus Come In - SCR, quench, pump gas question
ok, here's the deal. i'm building a 416 and i have some decision-making to do regarding establishing the deck height/selection of head gasket.
one possible scenario:
-.05 deck + .040 gasket = .035 quench = 11.71:1 scr
at the other end of the spectrum:
0 deck + .051 gasket = .051 quench = 11.27:1 scr
of course there are numerous other possibilities in between.
i want to strike a compromise between optimum quench and running comfortably on 93 octane pump gas.
suggestions?
P.S. - I haven't had any block machining done yet.
Old 03-09-2009, 09:27 AM
LS1Tech Sponsor
hellbents10's Avatar
.035 would be a great number to shoot for at 11.7:1.
Old 03-09-2009, 08:10 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ Depends on RPMs. .035 is tight.
Old 03-09-2009, 08:13 PM
Shawn @ VA Speed's Avatar
i would go with the piston out .005 and the .051 gasket,that would put you a .046 which is a really good number.
Old 03-09-2009, 09:21 PM
03 BUSA's Avatar
Running 12.5:1 with .040 gaskets here. .035 quench and 93 pump gas. My last setup had the same with just 12.0:1 with no issues. I would opt for the 11.7 number if it were me or you will be leaving some on the table. As long as you have a good tuner you will be fine.
Old 03-10-2009, 03:03 AM
Brad Hutchcraft's Avatar
damn 12.5:1!!!! I like the way you think! haha! Ill bet that exhaust sounds freakin sinister!
Old 03-10-2009, 06:46 AM
03 BUSA's Avatar
Thanks man, it does sound pretty mean even thru an open Borla. Don't get that bad crackle around 3k as bad either.
Quick Reply: Engine Gurus Come In - SCR, quench, pump gas question
