What are these things on my intake manifold??
Old 03-10-2009, 07:02 PM
FastKat's Avatar
Default What are these things on my intake manifold??
What are these things, and do I need them?
A - no idea
B - some sort of fuel pressure regulator? Is it vacuum operated?
C - This thing attached to B and I thought it went to my throttle body... but it doesn't look like there is a hole for it. It looks like a little vacuum line or something.
Thanks, -Dave
Attached Thumbnails What are these things on my intake manifold??-ls1-intake-pic.jpg
Old 03-10-2009, 07:28 PM
DiabloFormula's Avatar
A. Should be a vacuum tube that goes to your drivers side head.
B. Is the regulater and tubing for the EVAP system for your fuel tank.
Old 03-10-2009, 07:30 PM
conan's Avatar
A is the pcv hose.
B is part of the fuel evap system.
D_Rock's Avatar
That is your air/egr system.
Old 03-10-2009, 08:54 PM
massls1guy's Avatar
wrong/wrong
Old 03-10-2009, 09:18 PM
vsocks1's Avatar
What did you do....drop that thing in the mud?
Old 03-10-2009, 09:21 PM
JFM-jr's Avatar
That is dust everywhere else
Old 03-10-2009, 09:22 PM
regency's Avatar
lmao!! exactly what i was thinking
Old 03-10-2009, 09:25 PM
regency's Avatar
A: PCV Hose connects to a y fitting to each valve cover at the rear.
B: Evap solenoids
C: Vacumn for your fuel rail i think it goes to the back of the intake that capped on most
Old 03-10-2009, 10:51 PM
FastKat's Avatar
Haha I did not drop them in the mud - that's 3 years of dust from a salvage yard and a body shop.
So what the heck do I do with A, B and C??
A - vacuum hose, sounds like I should keep it. Right?
B - I don't even know what an EVAP system is or does. Is this something I should have? Does it have anything to do with my charcoal canister? Are both of those parts the EVAP?
C - ???
Old 03-10-2009, 11:18 PM
got-a-ls1's Avatar
You dont need either. But the pcv would be a good idea to keep. you could run a breather instead of PCV but it could get stinky from the crankcase fumes...
Old 03-11-2009, 12:03 AM
bczee's Avatar
A - is your pcv hose and system, connects both Valve covers and connects to a PCV valve to restrict oil and then be sucked the fumes / air back into the intake.
B- is your EVAP system, this suck the fumes from the fuel tank in to your intake system.
C- no sure..
A and B are part of the smog system to keep emission and fumes from escaping into the air. Do you need them?, will that fight will go on forever as usual.
They do have some benifits.. like the PCV system will add neg pressure inside of your engine crank case, cause positive pressure is not good, it will cause blowen seal and oil to be pushed out of you aftermarket breathers if you remove the PCV and just use Breathers.
Old 03-11-2009, 09:15 AM
FastKat's Avatar
Okay, so I think I see how the PCV system is supposed to work.
A - I installed an LS6 valley cover, so I can get rid of A, right? Just attach my PCV valve to the intake manifold and then run it directly into the steel hose-end on the LS6 valley cover? Then somehow cap off the nipple on the rear of the driver's side valve cover?
Also, can I use regular neoprene hose for the PCV system and that vent that runs from the throttle body to the passenger valve cover?
Do I need to put hose clamps on any of these connections?
B - EVAP System: So is there a separate line from the fuel tank that just carries fumes from the fuel tank to the engine in order to get burnt off?
Old 03-11-2009, 09:21 AM
massls1guy's Avatar
For 'A', have you seen the write up at ls1howto.com on the LS6 PCV, has some good pics:
http://www.ls1howto.com/index.php?article=18
Use fuel line from any auto parts store to replace the PCV hoses. The line has to be tough so it won't collapse under vacuum.
Old 03-11-2009, 09:30 AM
FastKat's Avatar
Yea, that ls1howto.com LS6 PCV article was what I used to install the LS6 valley cover in the first place. Very good article.
Fuel line it is!
Old 03-11-2009, 09:53 AM
slws608's Avatar
A=pcv system
b= evap solenoid system
c= air injection switch
Old 03-11-2009, 03:23 PM
BobDoLe's Avatar
is C a tiny vacuum line that connects to the map sensor?
i always thought that had something to do with the HVAC controls?
Old 03-11-2009, 03:37 PM
ItsNotStock's Avatar
It is. As soon as I broke (C) my heater controls stopped working. The ***** work, but you have no vacuum. It's impossible to see if it's broken, and one of the last things you would expect.
Old 03-11-2009, 05:06 PM
FastKat's Avatar
Ahhh, I bet that's it. For some reason I thought C went to the throttle body, but there was no hole there for it. I will check my MAP sensor and see if there is a spot for it.
I still think that C attaches to B somewhere... or what I have been told are the two parts that make up my EVAP system.
I guess I better search to see how the EVAP system works, and what can stay and what can go.
Old 03-12-2009, 02:48 AM
bczee's Avatar
B and C don't connect.
Evap plugs into the manifold port behind the T/B. it is a Brass port. then the other end goes to the hose that leads to the fuel tank.
Why don't you go highjax one of your friends F-Body and take some pictures of the parts and hoses.
