Why an Iron Block
Why an Iron Block
I have done a search and didn't find my answer.
If building a 6 liter build up why an iron block instead of the aluminum 6.0
How much hp can the aluminum block hold.
or is it just expense in most cases ( which seems odd on guys building 15,000 engines that a $350 would make a difference)
Thanks !
Thanks !
Dumb Ass Vette Moderator
I went the LQ4 iron block for strength. Once you start to make some big power, there will start to be cylinder wall flex. I am anticipating I will just to getting into the range of big power, so I wanted to eliminate that possibility. I believe the weight difference is about 85 pounds. By the way, the entire A/C system on a C5 is about 75 pounds
Also seen some higher hp builds in the old boosted lists running the iron block. LSX is of course also iron block for huge power. The 6.0 iron is cheaper also. It did add weight but like said you can offset some of that with things like lighter kmember and few other things.
I would think if every do another engine might go to the LSX if going to try to make really stupid power. I thought have seen the regular 6.0 take 1300 or so engine hp or maybe a bit more. Not sure if they were stock blocks or filled or whatever though.
Because you need the extra weight over the nose to hold the front end down. (see pics of Bobs Camaro on the EPP website)
Pros - All the things listed above plus no cyl sleeves to slip.
Cons - no place for the 3rd hole to mount the S/C bracket to the block (& you have to drill & tap the 2nd hole)
Thanks for all of the great replies guys! the metallurgy does make a lot of sence; less distortion easier to work on etc.
i'm planning either a 346 aluminum block or 370 iron block with an APS TT kit.
I'm looking to go no more than 800 HP to the rears. Probabally for now about 6 since I don't drag race a lot.
