LQ9 Swap, What to do ???
Old 03-11-2009, 09:43 AM
mighty-z28's Avatar
Question LQ9 Swap, What to do ???
Hey Guys !!! I'm upgrading a Camaro SS '00 with an LQ9 engine from a 2006 Escalade, What do I need to pass from the LS1 engine to the LQ9 one ???
Sensors ??? any Modifications to the LQ9 block ???
Thanks I appreciate all the help and comments
Old 03-11-2009, 09:55 AM
OUTLAWZ RACING's Avatar
Ummmm.... Nothing everything will swap over. Heads, waterpump altnator, power steering, everything will work just find. Ohh The altnator mount has one less bolt so thats it. good luck.
Old 03-11-2009, 09:57 AM
mighty-z28's Avatar
AWESOME !!! How about the sensors, do I need to swap those too or the ones in the LQ9 will work ???
Old 03-11-2009, 10:31 AM
sroach20's Avatar
only a couple sensors work, i used the crank sensor. i dont remember what else worked.
Old 03-11-2009, 11:41 AM
mighty-z28's Avatar
What do I need to do with that "One less bolt" ??? do I need to make it or it will be fine with just 2 bolts ???
Old 03-11-2009, 11:42 AM
sroach20's Avatar
12,000 miles with two bolts and no problems yet.
Old 03-12-2009, 02:22 PM
busa03's Avatar
Bump up.
I am about to do the same swap. So the computer will work? Any problems with a t56?
Old 03-12-2009, 04:21 PM
sroach20's Avatar
computer works and t56 works.
Old 04-25-2009, 09:40 AM
ALPHA Q's Avatar
I'm doing one also what else needs to be done? What else do you recommend to do? It's gonna go into a 98 with ls6 intake.
Old 07-18-2009, 06:59 AM
emolineaux's Avatar
im doing the same swap on my 98 z with a t 56 so far all the sensors off the ls1 swapped right over no problems. i had to slightly bend the coolant tube under the tb so my fast 90 and tb would fit.
Old 07-18-2009, 07:15 AM
Tough Mudder
Hilton's Avatar
The alternator Bracket would actually have 2 fewer bolts if you don't drill the boss.
The bolt hole that has to be drilled is a 10mm x 1.5. Start with a small drill bit. I used a 1/8th for the pilot hole, then swap in a larger bit (3/8th). Then tap the hole. Run the tap down and back several times. Use plenty of cutting oil the whole time.
Set the depth of the drill bit around 1.5". This will give the tap enough room to cut without bottoming out, enough room for the bolt.
It's easy. Nothing to it.
__________________________________________________ __________________________________________________ ______-
The oil pressure sending unit has to be swapped over. The truck uses a 3 wire, the f-body a 1 wire. I've always thought that the 1 wire was a stupid design. It's plastic, super tall, and after several years in an engine bay gets brittle. I've broken 3 of them. I've often wished someone would make a kit to swap in a metal one off a Ford. If I remember correctly, the 2004 GTO also has a 3 wire oil pressure sending unit.
Old 07-18-2009, 09:32 AM
Gaunt's Avatar
So what numbers are expected to be put down for that stock LQ9 in the camaro?
Nobody wants to post in my thread :/
https://ls1tech.com/forums/generatio...9-numbers.html
Old 07-18-2009, 10:38 AM
emolineaux's Avatar
i did have a tech question for the m6 guys that have done this swap. the motor im throwing in my 98 z is out of an 03 escalade. i just bought a monster stage 2 clutch with light weight chromoly flywheel. it came with a slave cylinder and pilot bearing. i was just wondering if the pilot bearing will fit and work fine with the t-56 backed up to the lq9, also any easy tips for installing the pilot bearing?
Quick Reply: LQ9 Swap, What to do ???
