Trivial but Im at a loss! Please help!!
Old 03-11-2009, 04:40 PM
HALF-BREED's Avatar
Default Trivial but Im at a loss! Please help!!
So I have installed a ls1/t56 combo into a 1995 240sx and when I was reading the installation manual they mentioned to install the motor without the starter in. Well now that the motor is in the I cant seem to get the starter in and its not because I cant get the starter to the opening! Its because the top edge of the starter is hits the block. The only thing I can think of is that when I bought the engine combo one of the bellhousing bolt holes was cracked and I had the guy swap it out with a different one. When we made the swap I held the two next to each other and they seemed identical and everything bolted up fine without the starter.
-Now am I doing something wrong when installing this, do I need to know a trick, or is there different versions of bell housing where the starter housing is bigger?
Old 03-11-2009, 06:52 PM
DaddySS's Avatar
Any way to post a pic?
Old 03-12-2009, 09:31 PM
HALF-BREED's Avatar
yes i will soon.
Old 03-14-2009, 05:13 PM
HALF-BREED's Avatar
so i found out that the issues was in the bellhousing it was off of a gto which uses a different starter.
