what octane would i have to run
Old 03-11-2009, 10:26 PM
Restricted User
kalebm22's Avatar
Default what octane would i have to run
what octane would i have to run to keep away from detonation at 11.3
Old 03-11-2009, 10:32 PM
SS MPSTR's Avatar
Need a bit more info on what else has changed. Likely 91 would suffice.
Old 03-11-2009, 10:33 PM
Hackscamaro's Avatar
at least 91 i would think you might be able to run 89 but you would just have to try it out and see. i know 91 would keep you away from detonation for sure though
Old 03-11-2009, 10:46 PM
Wicked94Z's Avatar
if your cam is a 208/212 on a 104 lsa you'll likely detonate on 91, so... more info needed here
Old 03-11-2009, 10:50 PM
Restricted User
kalebm22's Avatar
well i am planning on building a 383 stroker with 11.3 to 1 compression with ported heads and a 218/228 duration cam with 112 lobe seperation
Old 03-11-2009, 11:41 PM
myltwon's Avatar
why not just tune it for whatever gas you want to run?
Old 03-12-2009, 12:17 AM
Wicked94Z's Avatar
you'll be fine
Old 03-12-2009, 06:50 AM
transamws6_97's Avatar
why wouldnt you just put premium in the car? if you're going all out to up your compression and build a stroker motor whats the difference in spending a few more cents per gallon of gas...seriously
Old 03-12-2009, 07:15 AM
Restricted User
kalebm22's Avatar
lol i put premium in the stock bottom end i was just making sure it would be fine to run premium in the stroker motor. i just didnt know if 11.3 was going to be to high for it. i hope to get it tuned to run good on 91 though
Old 03-12-2009, 07:20 AM
z28rob18's Avatar
yea pump gas is fine. dont wanna hijack but dont want to start a new thread. 383 stroker not sure duration or lsa but in the .610-.625 lift range could i run 93 wit 12.1 compression?
nighthawk15's Avatar
10.5:1 is barely scratching the surface on what our engines can handle on pump gas thanks to the reverse cooling. There are a number of LT1s out there running around 12.0:1 and even higher.
Old 03-12-2009, 08:54 AM
myltwon's Avatar
I'll be a little over 12:1 when I'm done with my stroker
Old 03-12-2009, 09:11 AM
SpeedDensityZ's Avatar
I'd just go ahead and run premium. It cost a whole 20cent more than regular. My .02
Old 03-12-2009, 09:24 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
I ran 93 in my 393 when it was a daily driver....12.2:1 with 2 different cams...222/228 .544/.538 112 and 246/254 .613/.590 112. No issues at all. Just make sure the tune is correct and you run the correct heat range plugs.
Old 03-12-2009, 10:36 AM
Restricted User
kalebm22's Avatar
ok thanks for the help. but i never said i planned on running regular? i just didnt know how much compression i could crank out on 91 octane without detonation. i think i will be fine wtih 11.3 so thanks again
Quick Reply: what octane would i have to run
