What Belt for Ebay A/C Delete Pulley?
Old 03-12-2009, 08:03 AM
2XR95Z28's Avatar
Default What Belt for Ebay A/C Delete Pulley?
Hey i know some people on here have the same A/C delete pulley off ebay and i was wondering what size belt you guys went with? The pulley is about and inch or two smaller than the one on the A/C compressor so do i need a shorter one or is the pulley moved to where i don't need one?
Pulley looks like this, not sure if its the exact one but you get the idea...
http://cgi.ebay.com/ebaymotors/94-95...Q5fAccessories
Thanks guys!
Old 03-12-2009, 09:08 AM
RamAir95TA's Avatar
Your best bet is to measure.
Measure twice, buy once.
Old 03-12-2009, 09:17 AM
SpeedDensityZ's Avatar
I bought an A/C delete pulley from Advance Auto Parts. It's the same size as the compressor pulley. So I used stock belt length. That pulley looks a bit smaller though. Yep measure twice and buy once.
Old 03-12-2009, 09:32 AM
tonskiguy's Avatar
It's a lot cheaper tht the GM part. What do you think of the quality of that piece?
Old 03-12-2009, 10:01 AM
MTBSully's Avatar
they sell and AC delete pulley at advance?! How much was that? Dis you ahve to special order?
Old 03-12-2009, 10:07 AM
It was a day away at the warehouse and it was like 30.00 something dollars. It's 39.99 now.
http://shop.advanceautoparts.com/web...%7CGRP60000___
Old 03-12-2009, 10:10 AM
I've never had a problem with it. It's 10.00 more but, I didn't have to buy a new belt to use it. So, I guess you save a couple of bucks and you get it alot faster than ordering it from ebay.
Old 03-12-2009, 10:22 AM
harner's Avatar
I don't remember where I bought my pulley, either Advance Auto or Autozone, but it was $20 + tax. It was labelled as a "bypass" pulley so the stock belt worked. Of course it got squeaky so I ended up replacing the belt and it's been kicking *** ever since.
It's plastic, and you could tell it wasn't the best design, but it works fine for now.
The reason I had to replace was the A/C compressor locked up. After 10-15 minutes of gutting the car of the A/C system, it was relatively easy to install.
Old 03-12-2009, 10:24 AM
93TAJ.C.'s Avatar
You can get that delete pully at stores like that because it came stock on 1le cars if im not mistaken.
Old 03-12-2009, 10:25 AM
Elliott's94Z's Avatar
I just ran into this issue with my build. My stock belt was way too loose. I went with the Gates 060578. Fitment was just right.
Old 03-12-2009, 11:21 AM
litch2004's Avatar
I got mine from advance and my stock belt was too small I had to go one size up
Quick Reply: What Belt for Ebay A/C Delete Pulley?
