Help! Car runs faster in 3rd gear than in drive!
1 Post
I'm trying to see if the issue lies within the tune or the transmission. In the 1/4 mile, I have to run my car in drive or it will run out of gear if left in 3rd. (4L60E) I know I can get better times out of the car in the 1/4 if I can get it to run the same ET in Drive as in 3rd gear. Any thoughts?
Example:
1/8 mile run in 3rd: 6.53 with 1.41 60"
1/4 mile run in Drive: 10.57/6.75 () with 1.54 60"
We obviously had some traction issues with the 60" but it felt like it hooked to me; or maybe the car is programmed to be slower in drive? But the overall shift points are the same no matter what gear I race in.
Example:
The trans gets more pressure in 3/D. "Drive" for you is really overdrive. In Camaros it is labeled OD - D - 2 - 1, so some might get confused.
I would go a different gear or tire size. Maybe even bump the rev limiter. You really don't want to go into 4th/OD down the track. If you need to, I would be in 3 till you get half way down the track and then bump it up to D.
1 Post
your best bet would be to raise the rev limiter, depending on how high you are already spining it. Although if at 3/4 track you up shift, it won't shift till it actually hits the trans paramaters for a WOT shift, RPM and MPH. Staying in third would be faster if you can do it.
30's would slow you down. If the 28'' is working (it looks to be) I would stick with that. You want to run the smallest tire your car will allow.
1 Post
Your set-up is interesting; Would you mind telling me what #'s you run? Thanks again for the wealth of knowledge.
I hope to find out this weekend. The goal is 9's N/A
went mid/low 10's N/A last year with the LS2/cam only and less gear 3.73's (left about 20-30 mph in rpm range) and more weight (100-150lbs). The car has a glide so it is very dependent on the correct gear. I feel it was really hurting me.
This year is the LS3, 4.11's and lots of other goodies. Check my build thread in the staff vehicle section for more.
thanks!
What size cam do you have? 6100 seems kinda low. I shift my car at 7300, any less and it slows down.
thanks!
1 Post
thanks!
thanks!
1 Post
I tried much higher shift points, and the car falls on its face and runs 11's. Everyone's cam will have a different powerband unless they have the exact same cam/maker. I've never been successful with this cam shifting above the 6100.
If you have access to a tuner. I would just up the shift points in 3rd (along with rev limiter). Maybe even play with the other gears and see what works. I bet you have enough power up to 6400-6500 (stock rod bolt safe limit) to not require another shift. I know with comp, the cam description (not the specs) are just computer generated and they don't always test them. Thus, it might make power higher than they say.
edit: maybe not. lol
The rev limiter is set in the tune. You should be able to cross the traps at 126MPH close to 7000RPM depending on the amount of converter slip you have. I would push the rev limiter up to 7200 and set the shift point for 3-4 @ 135MPH to stop it from shifting into overdrive. What bottom end/shortblock setup are you running?
