SES light during high rpm shifts-->
I believe this is the correct place to post this. When I shift at full throttle or almost full throttle, the SES light will come on. Most shifts are around 4700-6000 rpm when this happens. I dont have a way to read the code, but was wondering if anyone would have any ideas as to what the problem may be. I've already tried replacing the TPS sensor, but no luck. After about 3 or 4 driving cycles, the light will go off. Like I said the only conditions that this occurs under are full throttle (or near) and at higher RPM shifts. Car and mods in sig. Thanks.
I had this problem for a while. Finally i was able to get the car in and scanned with it being on still, and it was a bad 02 sensor code. I seafoamed the car, and have never had a problem since
"Check the wiring harness. If not there then prolly either a bad TPS or misadjusted"
Ill check the harness and wires.
"I had this problem for a while. Finally i was able to get the car in and scanned with it being on still, and it was a bad 02 sensor code. I seafoamed the car, and have never had a problem since"
I never got an o2 code it is a tps code.
