Stock Pushrods OK With Dual Springs?
Old 03-12-2009, 07:13 PM
NodnarB's Avatar
Default Stock Pushrods OK With Dual Springs?
I'm doing a H/C swap with a Torquer V.2 and some ported 853's that have patriot gold's on them. I had the heads milled .020 and I was told I could run a stock length pushrod. My question is, could I run the stock pushrods or would they not hold up well against the much stiffer dual springs?
Thanks,
Brandon
Old 03-12-2009, 07:33 PM
BYE RICE's Avatar
Absolutly not.
Stock pushrods are barley adequate for a stock motor.
You could get by with stockers on a set up like yours to get from point A to point B only..& I wouldn't get on it.
Don't make yourself go back into your motor immediatly after you get it running.
Old 03-12-2009, 09:09 PM
tripblackls1's Avatar
umm any other input i know its not recommend but have people done it and what kind of results happend
i was planning on putting in my ms4 with prc dual spring and reusing stock pushrods?
Old 03-12-2009, 09:14 PM
Red99TA's Avatar
Why the hell would you spend the money on heads and cam and then not spend the extra $110 for pushrods? I think the length is probably ok but best to just get a pushrod length checker for like $20 and verify it yourself.
Old 03-12-2009, 09:19 PM
5.3LJimmy's Avatar
The stock pushrods will flex and bend with the dual springs. You are taking a chance of bouncing the lifters on the cam lobes and causing serious damage. I highly recommend that you spend the money for chromemoly pushrods.
Old 03-12-2009, 09:22 PM
well im installing the cam this weekend and i dont want to order pushrods untill i check it (i sure stock length is fine but if im getting new pushrods i should get the exact right ones) but i need my car to drive and can not have it down for a week or more
so how are stock pushrods with big cams and dual springs is the question, will i be able to go get the car tuned with them in (making several hard passes on the dyno?)
Old 03-12-2009, 09:24 PM
unless somebody here knows what a stock motor with ms4 needs for pushrod length but i searched and found nothing
Old 03-12-2009, 09:31 PM
ksk1980's Avatar
go w/ 7.4's hardened pushrods .
Old 03-12-2009, 09:48 PM
01ssreda4's Avatar
agreed with above...not just no but hell no
Old 03-12-2009, 10:10 PM
SweetS10V8's Avatar
I swapped out my pushrods within 100 miles of having it, on the stock engine. The stock ones arent even good enough for stock.
Change them no matter what.....
Old 03-12-2009, 10:23 PM
NodnarB's Avatar
Thanks guys. That's all I needed.
Brandon
Quick Reply: Stock Pushrods OK With Dual Springs?
