Drag Racing Tech - ???SPEED INC still make the FUEL TANK for FACTORY LOCATION.....
nemss1
03-13-2009, 09:52 AM
cant seem to find the fuel tank on their site
tank mounts in factory location
DanZ28
03-13-2009, 01:34 PM
I don't think so, but http://www.nastyperformance.com/default.html does.
nemss1
03-13-2009, 01:40 PM
thanx dan. will have to save up for an aftermarket setup. kinda broke at the moment
Z28/2002
03-13-2009, 03:11 PM
aluminum with a sump
Z28/2002
03-13-2009, 03:15 PM
To the OP, there is one in the for sale section. A little cheaper than what Nasty wants for thiers
http://www.ls1tech.com/forums/lsx-parts-sale/1070449-fs-speed-inc-sumped-alum-tank.html
nemss1
03-14-2009, 07:57 AM
thanx man, will look into it
IllusionalTA
03-14-2009, 10:13 AM
Yep it's still for sale.. Got lot's of offers.. but none realistic... :)
nemss1
03-15-2009, 09:17 AM
i heard these tanks are a prob if still running the stock routing of exhaust?
IllusionalTA
03-15-2009, 09:35 AM
Yes and No... depending on how your route the an fittings.. you could get around that issue.. as the sump feeds to the side rather than the back...
nemss1
03-15-2009, 03:00 PM
thanx for the info man
IllusionalTA
03-15-2009, 03:12 PM
u should buy mine LOL
9sec93
03-15-2009, 04:08 PM
where the sump is it hangs down just as low as the t-top well in back. so yes routing exhaust out the back could be a pain. i had the same one annd got rid of it for that reason.
Tom@SpeedInc
03-15-2009, 04:16 PM
Since most ppl have the plastic tank, often we will install bulkhead fitting for an inline pump.
you can also use your intank fuel pump in combination with an inline pump
We've run this past 1000rwhp.
http://i177.photobucket.com/albums/w218/speedinc1/zillyfuelsystem.jpg
nemss1
03-15-2009, 11:08 PM
i dont like the sound of that. kinda pushing me away from that decision:lol:
i would if i wasnt so picky on EVERYTHING i buy for the car:jest:
Big Bird WS6
03-31-2009, 10:15 PM
you trust this?
i have to run three pumps like oyu have. but what did you use to make sure it did not leak?
Big Bird WS6
03-31-2009, 10:16 PM
also to the OP. speed inc got there tanks form behindbarsracing. google it. or pm me for the website. i have one. for customer car. looks great. and was cheaper then a few others around here
why me
04-07-2009, 05:20 PM
ok what about if i have a plastic welder. then were do i get the stuff to sump it?
Tom@SpeedInc
04-27-2009, 03:40 PM
you trust this?
I run that similar setup on my own car and it works fine, no leaks, pressure tested.
You just have to use the proper washers, these are provided with the correct bulkhead fittings
Fraser
