OEM Parts
do you have a website that i can go and search for part numbers? i have a real hard time finding part numbers. i need a lot of nut, bolts, and small things and it would be easier if i could just get the part number and order them instead of saying "i need the lower control arm bolts," etc.
LS1 reluctor wheel
Can you give me a price on a 24x LS1 reluctor wheel? It's going on a Scat stroker crank that will be nestled into an LQ9 block and run with a 2001 Camaro SS PCM/sensors. As far as I know, none of that matters because the 24x reluctor wheels are all the same? Please correct me if I'm wrong. Thanks.
Jeff
Jeff
