Some early track results
Old 03-14-2009, 10:02 PM
C_Rules's Avatar
Default Some early track results
So I decided to take the car to the track today. The fastest pass of the day was a 12.81. Not really what I was hoping for since I'm shooting for 11s. Did run into some issues like two tranny DTC errors on the first two passes one for TPS voltage low and speed output loss. Then my a/f ratio was erratic. maybe due to my split BLMs even with a BLM locker on my tune my Left LT was stuck at 140+. I'm going to work on getting that fixed and keep messing with the tune to hopefully hit the 11s but don't know if its possible since the mph isn't really there.
RT... .249
60...1.763
330...5.273
1/8...8.179
MPH...84
1000...10.7
1/4...12.818
MPH...106.7
Old 03-14-2009, 10:36 PM
96lt1m6's Avatar
Hmmmmm, what heads, cam, stall ?
i am certain there is an issue going on more than described!
Old 03-14-2009, 10:45 PM
C_Rules's Avatar
Heads: stockers ported and polished, 2.02 1.60 vales, 1.6 crane golds rockers, crane springs 135 lbs on the seat
Cam: 224/236 574/572 111 lsa
Stall: Vig 3200
i datalogged the car didn't really notice anything major on the healthy runs.
Old 03-14-2009, 10:51 PM
ZeeTwentyFate's Avatar
relitively small cam for that CI...
Old 03-14-2009, 10:57 PM
1989GTA's Avatar
The proper tune could have a big impact. It also sounds like you have some issues to sort out.
Old 03-15-2009, 12:01 AM
96lt1m6's Avatar
No tune is mentioned!
small cam but should still run better than described,LPE 211/219 will go 11s
Old 03-15-2009, 08:49 AM
C_Rules's Avatar
i tune the car myself.
Old 03-15-2009, 08:52 AM
z28rob18's Avatar
yea those times dont seem right for a heads cam 385.
Old 03-15-2009, 09:33 AM
96lt1m6's Avatar
from what i see, you may want to have someone else tune it for you.
not tryin to be a jerk but you should not be running any 13s
Old 03-15-2009, 09:54 AM
LM97Z's Avatar
Yeah, you need to check things out, at 1st. i thought it was a stock bottom end, but a 385, its WAY off, even with that smaller cam, you should be pushing 11s, if not there allready, most likely its in the tune, the fuel tables & timing may be way off, that can easily kill a good second & 7-10 MPH.
Old 03-15-2009, 10:08 AM
C_Rules's Avatar
i hear where you're coming from but after looking over everything there may be a mechanical issue. probably due to a leak of some sort either exhaust, vacuum, or a combination of both. check out the attached log and you can see that the O2 mV readings are showing there is a problem. the right O2 is in the 900s after 3,000 rpm while the left is all over the place. at WOT the BLMs which are supposed to be at to 128 are not. The Left Long Term BLM is at 150 which effects the Left Short Term Trim causing little lean spikes. That may explain the erratic a/f. I also have an issue with split BLMs during normal cruising. I'm going to sea foam the car to see if I can find any leaks and swap the O2s around to see if the problem switches sides as well. If so that would mean I need a new left O2 sensor. That would suck because i just bough two new O2s like 3 months ago. Don't know how one would go bad so fast.
File Type: zip
Old 03-15-2009, 10:34 AM
ABA383's Avatar
My cam is smaller than that...I dont think the size of the cam is the issue...
--Alan
Old 03-15-2009, 10:39 AM
96lt1m6's Avatar
i ee your point however o2s are along for the ride when drag racing (wot) i am not a tuner......my car runs the same ET with o2s dead, now cruising around is a different story ..... would spend the money on a tune
Old 03-15-2009, 10:44 AM
ABA383's Avatar
Yeah it sounds like something in the tune...Are you willing to have it tuned or at least send the computer out to someone to look at? I'm good at losts of things with these cars but tuning aint one of them...I use Bryan at PCMforless...My cam is 226/234 .568" on a 111 and you see my times/mph in my sig...
--Alan
Old 03-15-2009, 12:19 PM
C_Rules's Avatar
Okay guys I'll take it to a pro to look at it to rule out if its the tune or not.
Quick Reply: Some early track results
