installed meth inj.? some opinions needed
im doing a diy meth injection, and i wanted to know where some other people have put theyre injector. i have a twin intercooler procharger setup and i was thinking i could put it on the bottom side of the collector box. in your opinion is that a good place? the only thing i was worried about was having it before the maf have some of you out there had any ill experiences putting it there? any input is welcome and appriciated
so 4 of 4 say after the maf ..... i have an extra tb laying around i suppose i will experiment on that on and see where the best location for me will be thanks for you input everyone if this works out i will post the parts and where to buy the stuff needed for the DIY meth kit that has costed me 30 dollars so far
run it after the MAF, but before an Air Temp sensor. that way you can take advantage of the cooler air. Then if the system failed or ran out of meth for any reason it would notice the rise in air temp and it could pull timing
