Coolant leak HELP!
Coolant leak HELP!
Replaced my water pump and i got a leak at the inlet hose. The upper radiator hose that goes into the water pump leaks right at the end. I replaced the house and put a good "constant torque" clamp that really clamped it down. It did not cut into the hose and the hose is seated nicely. not sure what else could be the problem. its a slow leak but enough where i have to add a little coolant every couple days. any ideas?
i did,pressurized it to 15 psi and got a dribble coming from the end of the hose. idk how to stop it. the hose is clamped nice and tight
