cracked block
Old 03-18-2009, 05:22 PM
817Borla's Avatar
Angry cracked block
ok so i just finished my h/c, anyways i go under the car to clean up the oil pan and i see this
looks like one of the bolt holes still had coolant in it, kinda weird since i didnt feel any resistance when i was torquing them.
anyways whats done is done and im guessing the block is no good right?
well i found an complete LQ9 with 43k miles for 1500, i did a bit of searching and from what i understand everything
should swap over or are there some exceptions? i have PRC stg1 ls6 heads, Polluter Cam, Ls6 ported oil pump, LT's,
Fast intake 78mm (will be porting to 85) and 25% UDPulley.
Old 03-18-2009, 05:33 PM
demonpixel's Avatar
Not to sound dumb but can you not magnuflux that?
Old 03-18-2009, 05:44 PM
SS02's Avatar
ouch !!
Old 03-18-2009, 05:45 PM
LS1MCSS's Avatar
Magnuflux is for finding cracks. You don't need it to see that one.
Old 03-18-2009, 05:47 PM
slowandrichws6's Avatar
if you didnt have any resistance while you were tourquing them you had a problem.
Old 03-18-2009, 05:51 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Magnaflux = only works with things that can be magnetized....alum = nonferrous
alum pieces are pressure tested.
Old 03-18-2009, 07:34 PM
817Borla's Avatar
so.... would my heads work good with the lq9 or should i get new heads?
Old 03-18-2009, 07:57 PM
HUNTER02SS's Avatar
The problem is you should NOT be torquing your head stud's only the nuts. The studs are hand tightened into the block and you only torque the nut's!
Old 03-18-2009, 08:36 PM
Jimmy P's Avatar
Yup. We usualy hand tigthen the studs to the block until they can't go any further, then go a quarter turn back. The studs shouldn't be touching the block, and deffinantly shouldn't be torqued to the block.
When I bought my car used, the previous owner had done the same exact thing. The block was cracked, but I didn't find out about a year later when I took the block to a machine shop to get a bult bottom end. Oddly enough, it wasn't giving me any problems, atleast not that I knew off..I ended up buying a new block just to be on the safe side.
Old 03-18-2009, 09:22 PM
JUNK's Avatar
Also, it is not enough to just blow the holes out, u have to use a tube and blow from the BOTTOM of the hole to get all coolant out.
Old 03-18-2009, 09:47 PM
817Borla's Avatar
you think i should run it like it is or go ahead and get the lq9 to be on the safe side?
i was about to order me a performabuilt lvl2 tranny but found that dam crack and it changed my plans quite a bit lol.
Old 03-19-2009, 06:43 AM
LS1TECH Sponsor
mikey's Avatar
You didn't get all of the coolant out of the bolt holes and when you forced the studs in, the coolant took the easiest way out.
Quick Reply: cracked block
