complete noob to nitrous need help with fogger
I want to do a fogger dry shot to my car.. I have recently bought a ported fast 90 how would be the best most creative way of hiding the fogger nozzle, and and please someone sort of guide me in the right direction as far of whos kit is the safest and what I will need tuning wise and parts wise ect.
I heard i can hide the nozzle behind the intake or under it but idk the truth to that
Anyways any help is appreciated thanks
LS1TECH Sponsor
A single nozzle (WET) should be 4-6 inches before the throttle body. You could put it at the bottom of your intake tube so as not to be seen as easily. As long as you have some safety items such as a window switch and FPSS, most any kit should be fine.
Depending on how much nitrous you are looking to move, you may need to upgrade your fuel system.
Depending on whether you have coil packs or a single coil there are some options as to how to pull timing. LS1: Timing Tuner, Lingenfelter or just a good dyno tune. LT1 etc.: Mallory 685, MSD Digital 6 or a good Dyno tune.
If your dead set on a dry kit, you will probably have to upgrade your injectors to remain safe on fuel as long as your pump will handle the extra fuel load.
Nick
