How Universal are the LS series Engine dampers?
Old 03-19-2009, 02:03 PM
BadgeZ28's Avatar
Default How Universal are the LS series Engine dampers?
Can you use the harmonic dampers off the trucks on the cars? Did they change with the evolution of the motor?
Old 03-19-2009, 02:50 PM
S10xGN's Avatar
They're only specific to the front acc'y drive system being used. Different front drives (as a system) are spaced out from the block face at certain depths. The depth of the balancer is dependent on the depth of the other pulleys.
Russ
Old 03-19-2009, 03:17 PM
BYE RICE's Avatar
Don't try & run a 'vette damper on an F-body.That's the only one I know of from experience.
Vette dampers are shorter.
Old 03-19-2009, 06:23 PM
NemeSS's Avatar
as fas being universal, yes. but will require a the matching front accesories.
i.e. u can use a fbody pulley along with the acc. and everything will be fine.
no need to have anythig balanced
Old 03-19-2009, 06:30 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Texans UNITE...haha. Yah they are specific for the most part, but the F body is used on teh GTO. The vette is used on the SSR and the G8. Trucks are by themselves. Thats pretty much it. dont remember on the ctsv tho. my guess would be F body, since the gm serpentine kit is offered for use on the F bodys and normally comes on the ctsv.
Old 03-19-2009, 09:30 PM
raven154's Avatar
Negative ghost rider, CTS-V uses the Vette short accessories. I have one so dont think I'm just talking out my ***.
Old 03-19-2009, 10:02 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
really. well that is why i was not too sure. i was too busy to look in the GM cat. ill look tomorrow to get something more solid
Old 03-20-2009, 09:10 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
raven is correct. they do use the vette style (non LS7) balancer
Old 03-20-2009, 09:21 AM
99blancoSS's Avatar
Just and FYI the GTO uses the Fbody balancer
Old 03-20-2009, 10:12 AM
LS1Tech Sponsor
Beau@SDPC's Avatar
Already posted that. 4 posts up.
Old 03-20-2009, 10:18 AM
99blancoSS's Avatar
hehehehe, didnt see it. Good call
Old 03-20-2009, 10:57 AM
BadgeZ28's Avatar
Thanks for all the info. Should be part of a sticky. So I will need to remove my F-Body damper and accessories and install them on the new iron truck block, to fit back into the F-body.
Old 03-20-2009, 08:41 PM
chriss71z28's Avatar
So if i have a 6.0L truck short block, i can change the balancer to a f-body one and use the alt and p/s pump too on the truck short block? I'm still learning about these new motors. I'm a old school small block guy. Thanks
Old 03-21-2009, 02:19 PM
NemeSS's Avatar
correct, u must use fbody accesories along with fbody damper. truck has diff. offset and configuration
Old 03-21-2009, 05:29 PM
Ok that sounds good. Do you have to have the parts rebalanced when changing a balancer? Or are they just zero balance? Thanks
