drivers side on steam pipe not sealing
Old 03-20-2009, 05:26 PM
96Formula6spd's Avatar
Default drivers side on steam pipe not sealing
Hey guys I am having trouble getting my drivers side steam pipe to seal up. The bolt tightens down but coolant keeps coming out. Does anyone have a picture of the back of the engine with this piece on. I have new gaskets on but it just wont stop leaking any ideas?
Old 03-20-2009, 05:31 PM
ss.slp.ls1's Avatar
Did you use two new gaskets per head? The banjo bolts need one gasket on each side of the pipe.
Old 03-20-2009, 05:32 PM
no just one thats all that was on it when removed
Old 03-20-2009, 05:35 PM
ss.slp.ls1's Avatar
No there are two. Pull off the steam pipe, remove the banjo bolts, you will see the second one that goes between the pipe and the head of the bolt. Bet you that washer on the driver side is the one that is leaking.
Old 03-20-2009, 05:47 PM
probably is the one leaking. There is no washer there. Going to have to take it back apart go get another $8 rubber washer and hope this works. Otherwise I am getting it towed
Old 03-20-2009, 11:52 PM
Nads06111's Avatar
where is this located?
Old 03-21-2009, 12:14 AM
strokin93z's Avatar
the pipe is located on the back of the heads. runs right behind intake. not sure if pic worked. but tis the little line that runs from one head to another. Hope this helps. And for the OP, i didnt believe there was 4 either when i took mine off, but there was. Good Luck!
Last edited by strokin93z; 03-21-2009 at 12:15 AM. Reason: Sorry for huge pic! can someone resize? :P
Old 03-21-2009, 09:30 AM
shbox's Avatar
NAPA 730-2922 is a cheaper alternative to the GM seals.
Quick Reply: drivers side on steam pipe not sealing
