vfn lift off hatches
if the glass is most of the wieght then it is not worth the cost for me but if there is 10lbs to be saved using the hatch then I may reconsider but my problem is with mounting it as I was hopefull of having a full frame but was informed that it uses the glass to atach to the body and not a hatch frame and I do not feel comfortable relying on a 1/8th in thick lexan window to hold up on my street/strip car.
Got curious about a pin on/ lexan hatch.... got in a argument with i guy cuz i said it was a 75# reduction from the stocker......
Lexan sitting next to it. just Weighed it......10#
Stock Hatch w/o glass(mine window got busted outta it) 58#....just weighed it also
So......
10 Lexan Window
8 Hatch - VFN Hatch 93-02 is posted as 8# on their site
2 hardware
20# total
EDIT
Stock
58 Hatch
30??? Glass maybe
... hatch dampeners & hinges
... hatch lock/latch
88#
So depending how far off i was on guessing the window weight it came to 68# weight reduction
SO IF ANYONE HAS A STOCK REAR WINDOW FOR A INSTALL U SHOULD TOTALY WEIGH IT
