317 heads on ls1 what push rod?
Old 03-24-2009, 07:23 PM
dudeman's Avatar
Default 317 heads on ls1 what push rod?
i looked around on here and saw that the 7.425 are the ones to run. i heard that 7.400 would work. anyone have solid info on this? would 7.400 work? i should be using 02+ z06 cam if that matters.
Old 03-24-2009, 07:34 PM
02blackbeauty19's Avatar
Im interested to know as well
Old 03-24-2009, 07:42 PM
Sluggish's Avatar
I have 317s and am running 7.400" pushrods. We used a gauge to make sure we had they would work before installing them.
Old 03-24-2009, 07:51 PM
I have 7.400" but I will also be checking just to make sure
Old 03-24-2009, 08:03 PM
dudeman's Avatar
thats what i wanted to here since i already have a set!!!
anyone else using 7.400?
Old 03-24-2009, 08:46 PM
conan's Avatar
7.400 here too no problems.
Old 03-24-2009, 09:39 PM
mcmillion's Avatar
7.400 for me too, on Lingenfelter 317's
Old 03-25-2009, 04:10 AM
Chris10an's Avatar
Exclamation
Run 7.400 on a 317 with a stroker/P1sc blower and a compcam xr281HR-12. No problems here.
Old 03-25-2009, 07:06 AM
pwrtrip75's Avatar
why would they differ? 5.7 heads are the same as 6.0 heads. I used the stock size ones.
Old 03-25-2009, 07:28 AM
Phantom's Avatar
I'll be using 7.425s with a 02+ ls6 cam and 317s
Old 03-25-2009, 07:35 AM
NightMoves's Avatar
I found spec for XER281HR @ 232/234 & .595/.598, is that what you have or if not what's the diff? Does the -12 mean 112LSA? If not what LSA is yours? What kinda boost you running? PM me if you can, not trying to steal the thread.
Most cams call for 7.4 push rods ( stock length ) unless you have milled the heads.
Old 03-25-2009, 07:37 AM
Phantom's Avatar
The deal with needing the longer p.r. With the ls6 cam is the smaller base circle
Old 03-25-2009, 08:40 PM
dudeman's Avatar
what head gaskets do you guys have?
Old 03-25-2009, 08:53 PM
kbracing96's Avatar
I used stock 7.4 PR's and Stock 6l gaskets on mine
Old 03-26-2009, 07:07 AM
sujomatt's Avatar
yea u use stock pushrod length unless its a nonstock cam. in my case i have the 02+ z06 cam, so i used 7.425"
Old 03-26-2009, 09:03 AM
Dumb Ass Vette Moderator
ls1290's Avatar
LS1Tech 20 Year Member
7.400" pushrods with my TEA Stage III FI 317s.
Old 03-26-2009, 12:26 PM
dudeman's Avatar
why do some people have 7.4 and some have 7.425? different cams?
Old 03-26-2009, 01:37 PM
1CAMWNDR's Avatar
Different cams and different headgaskets will dictate different pushrods. Stock for stock they will use the same 7.400 pushrods as a stock 02 LS1.
But I am sure you will be getting a cam too............
Quick Reply: 317 heads on ls1 what push rod?
