Lets see some APS dyno graphs.
Lets see some APS dyno graphs. Tell us what comp. the motor is, cubes, and which APS kit you have. If you have a custom TT kit lets see your graphs to. I just want to see where boost hits, what RPM you peak and the torque. I just bought the Exterme APS kit and it is going on a 408. Thanks
i dont have the graph on the computer but ill give ya the info...
APS standard kit
-402ci
-l92 heads (stock unported)
-custom grind cam
-9.1:1 compression
-9psi it made 723rwhp (on pump, no meth or alcky) peaked at 5800rpms...ran out of fuel
made 789rwtq
-boost starts coming in at about 2800rpms and im at full boost in a matter of seconds..approx. 3600-3800rpms.
im upgrading the injectors and turbos toward the end of the summer.
APS standard kit
-402ci
-custom grind cam
-9.1:1 compression
made 789rwtq
APS standard kit
-402ci
-custom grind cam
-9.1:1 compression
made 789rwtq
APS standard kit
-402ci
-custom grind cam
-9.1:1 compression
made 789rwtq
APS standard kit
-402ci
-custom grind cam
-9.1:1 compression
made 789rwtq
APS standard kit
-402ci
-custom grind cam
-9.1:1 compression
made 789rwtq
If you use the search function try typing in "aps dyno" with the quotation marks. You should get some results since no one has posted up anything yet. Good luck.
402ci 6.0 iron, 10:1 compression, Dart 225 heads w/ patriot duals, FAST 90mm, 225/225 113LSA camshaft.
going to swap out the cam someday for 230/230
through full magnaflow catback, sounds quieter then stock
Red is .5 bar WG springs
Blue line is Eboost2 showing 12psi (had tire spin)
