What Rocker Arm set up for MS3 cam.
Old 03-28-2009, 06:32 PM
MYSTIC-1SC's Avatar
Default What Rocker Arm set up for MS3 cam.
I was just curious what ratio rocker arm i should go with? the car is a bolt on car with stock heads and MS3 cam. i was just wandering if the 1.7:1 would be fine or to go with the 1.8:1, and possibly what difference it might make. Let me know what you guys think.
Old 03-28-2009, 06:36 PM
ksk1980's Avatar
stick w/ the stockers they'll be fine . thats what i did w/ my ms3 setup
Old 03-28-2009, 06:42 PM
sixpack_2_go's Avatar
1.7 ratio stockers will be fine. if you want to go with an aftermarket upgraded rocker, go with the 1.7 Yella Terra ultralite. i run those on my car and love them. i've read through many posts about them and never heard a single bad thing about them.
Old 03-28-2009, 06:53 PM
MYSTIC-1SC's Avatar
ok thats fine, i have just heard that over time running a cam with over .550 lift with the stock rocker arms can cause premature valve guide wear.
Old 03-28-2009, 08:39 PM
LS199CAMAROZ28's Avatar
yea i think thats what they recently said in gmhtp. i'm going to use the stockers with my ms3
Old 03-28-2009, 08:43 PM
MYSTIC-1SC's Avatar
yes they had an article were this had been an issue.
Old 03-28-2009, 09:30 PM
the stock rockers have been know to wear out and **** out needle bearings. happend to my buddy with a H/C 01 ss. mine started to come apart at 78k miles, after 10k miles with my 646. lift cam. i switched to 1.7 Yella Terra ultralite
Old 03-28-2009, 09:44 PM
MYSTIC-1SC's Avatar
thanks for the advice guys.
Old 03-28-2009, 10:02 PM
Old SStroker's Avatar
What do the people who designed/sell the "MS3" cam recommend? They should know better than the rest of us what to use with their cam, don't you think?
You might look over the recent threads on rocker arms. You might look farther than this forum also. Doing your homework can save you money, time and broken parts. If you can find a good LS valvetrain person, ask him for advice.
Jon
Old 03-29-2009, 09:51 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Running the stock rockers with my MS3
Quick Reply: What Rocker Arm set up for MS3 cam.
