Automatic Transmission - B&M tranny cooler install
LCplmarine98
03-31-2009, 01:46 AM
Anybody know if the B&M tranny coolers are a direct replacement for the sock one or do they require new fittings and brackets to mount? All the sites i have looked at for buying one dont explain it.
PontiacFan
03-31-2009, 10:50 AM
An aftermarket transmission cooler is typically mounted after the stock unit, which is in the radiator.
For all I know, there would be no 'direct replacement'.
RooRnZ28
03-31-2009, 01:12 PM
I have a B&M with a fan, and my mechanic had to make a bracket in order to properly mount it. I'm sure with any cooler, some sort of strong mounting support will be needed.
01ssreda4
03-31-2009, 06:49 PM
if you get the B and M cooler with the installation kit then it will come with everything you need....
LCplmarine98
03-31-2009, 08:11 PM
I have never seen an install kit. Any idea who sells one?
01ssreda4
03-31-2009, 10:03 PM
no its not an install kit, its a cooler with fittings hoses clamps and shit and its slightly more expensive then just the cooler.
01ssreda4
03-31-2009, 10:04 PM
here ya go
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70264&N=700+400004+1004+115&autoview=sku
LCplmarine98
03-31-2009, 10:11 PM
Cool thanks
12secSS
04-01-2009, 11:00 AM
That is the one I always recommend! If you need help installing it, let me know as I have installed several of these things. :)
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
