Trans covered in Eng Oil.......
well last week whil at the track, my car had a puddle of oil under the trans, looked more up there and the trans is covered in oil, yet the engine shows no signs of oil.
talked to my buddy and said it sounds like the oil sending unit.
just took it off and it looks good, but im going to change it, the oil appears to be coming from the cam sensor, so im going to replace that as well and take no chances.
thoughts-opinions?
thanks
brandon
thoughts-opinions?
thanks
brandon
if you got coolant in your crank shaft you have a bigger problem than just an oil leak. At the rear center of the crank shafts (LS1 engines) is a small "freeze" plug, when its leaking it leaks oil because the crank shaft is supposed to be full of oil, for lubricating stuff yo. Yeah, dumb ****** place for a oil freeze plug but hey, I didnt design it. If theres oil all over the top of your trans, probably what you said, if only botton of trans start checking main seal area. There should be a small access cover on the bottom of the bell housing, pull it and check inside the bell housing for oil. That was alot of typing, I'm done.
There is a freeze plug in the back of the crankshaft. They can come out of place at times, and when they do it causes an oil leak. This is the same reason why you have to be careful removing the pilot bearing on an LS1 crank.
thoughts-opinions?
thanks
brandon
thoughts-opinions?
thanks
brandon
Russ
I had the same problem....about the 3rd pass id make"every trip to track"rhere was a huge puddle of oil under the car.....i changed cam sensor,oil sender,rear main,rear cover gasket,oil pan gasket......it ended up being a head gasket...the old motor had alot of miles....mine seemed to push the oil on the top end of the track when i would shut the car down......good luck....
ok so i replaced the cam and oil pressure sensors.....
everything looked good no leaks untill i went back to the track. started getting the leak again, still on top of the motor.
could it be the valley cover? or what else can i change out? or could it be coming from the timing cover?
thanks
brandon
thanks
brandon
if the freeze plug in the crank leaked no way the clutch would not start slipping with oil all over the trans.
Brandon check the valve cover gaskets..... might be? or even that rear driver side grommet? you have a catch can, whats the pcv setup?
maybe that rear headbolt hole has a crack? that should be a coolent leak I think but Im sure anything can happen. Ive had import friend just had a poruse block weep, when they tuned the boost up. But it was fine for 50k miles. No crack, just bad porsity (sp? whatever that word is)
rear driver side gromet is good and no leaks, i guess ill pull the valve covers to check those thatll be easier then pulling the intake again, maybe ill get lucky.
if this helps, i saw a lil oil gathering right under the intake near the valley cover, def not the intake tho.
