o2 sensors
Old 04-03-2009, 07:22 PM
Elliott's94Z's Avatar
Default o2 sensors
In the mix of changing out my original o2 sensors and curious to know what brand you guys suggest going with?
Thanks Elliott
Old 04-03-2009, 07:26 PM
ss.slp.ls1's Avatar
Thanks Elliott
Same as the one's you got in there now, new AC Delco's.
Old 04-03-2009, 07:45 PM
Good deal. Didn't know if going with some NGK or Bosch would be any better.
Thanks!
Old 04-03-2009, 07:48 PM
RamAir95TA's Avatar
Delco all the way.
Old 04-03-2009, 07:50 PM
95zsean's Avatar
Bosch for 3 seasons... no troubles.
Old 04-03-2009, 07:52 PM
Damn just got off the phone with Summit...the Delco's are $70 each! Bosch were $52 and the NGK were $42. Is there really a difference is quality with a o2 sensor? Will one brand last longer then the other?
Old 04-03-2009, 07:55 PM
RamAir95TA's Avatar
I tend to stick with AC Delco for all electronic parts/sensors, regardless of the price.
Old 04-03-2009, 07:56 PM
ss.slp.ls1's Avatar
I know that when you order a mail order tune from MadTuner, they say that their tunes are specifically designed work with AC Delco o2 sensors. I have heard of both good and bad things with the Bosch units. But I have never heard of bad things about AC Delco's.
As always I check on GMPARTSDIRECT and the Delcos were less expensive. Getting them! Thanks guys
Old 04-03-2009, 09:09 PM
camerory's Avatar
Yeah, I just put my tuned computer in from MadZ and they do recommend AC Delco.
I used those when I installed my Mac headers and they work real good. I just had the egr tube bolt (on the headers) back out which set a code for Bank 2 lean exhaust. I knew the O2's were working, so I tightened the bolt up and hit it with some RTV red to mark its position. No code now.
Old 04-04-2009, 08:31 AM
97pontta's Avatar
Can you still get AC Delco O2s? The last time I bought mine they came as Delfi, or is that considered AC Delco?
Old 04-04-2009, 08:45 AM
camerory's Avatar
Yeah you can still get them, they are AC Delco P/N AFS75 or GM P/N 19178930.
Old 04-04-2009, 08:47 AM
97pontta's Avatar
Thanks
Old 04-08-2009, 06:30 PM
camerory's Avatar
How did those AC's work out for you? Also, that video clip in your sig is awesome. You have a quality setup there.
Old 04-08-2009, 08:56 PM
Still on order bro. Thanks for the comments...appreciate it!
Old 04-09-2009, 06:43 PM
camerory's Avatar
Just to let you guys know, my car was still running like crap after I tightened everything up. So I swaped the stock AC delco sensor in I had and it fixed the problem. The new cheap Borg Warner sensor I bought (suposively the same thing as Ac Delco AFS 75) took a crap. So I am only using AC from now on.
Quick Reply: o2 sensors
