Anyone running Centerline Telstars?
I was wondering what backspacing i need for the rears? Should i get 15''x10'' or 15''x8''? What all do i need to do to get them to fit on my car. I already have the fronts.
I have longer studs on my car. I ran a spacer on the front, and had ground down one the rears alot more than should hav. and still didnt fit. I have seen it done. with alot of grinding. I was going to swap to lt brakes-which they will fit. but went different wheels.
What year is your car? and the rear being narrow will allow the rim barrel possibly clear the brakes. On LT cars these will fit no problem. But LS brakes will fit with a thick spacer on front. But rears stock width with alot more grinding than welds. or you can switch to LT rear brakes. The Convo line will fit no prob.
