Who runs stock radiator?
Old 04-05-2009, 02:54 PM
LS1Silverado05's Avatar
Default Who runs stock radiator?
I have been looking at standing up the radiator...and it seems like almost everyone gets a Griffin. Is there no good way to stand up the stocker and have clearance for a single T70 front mount? Who here has reused the stock radiator in the set-ups?
Old 04-05-2009, 03:01 PM
dsmawd350's Avatar
nobody.....when stood up vertical the stocker is too tall.along with the angled inlet
Old 04-05-2009, 04:12 PM
So even when the lower mount is re fabricated it wont work? I know for a fact they can be made to fit under the hood...I was more worried about the width and depth with fans...
Old 04-05-2009, 04:15 PM
52172's Avatar
I do...., but mine is not stood up.
Old 04-05-2009, 04:25 PM
Well I dont care if its stood up...I just want it to clear a T70...I wont be running ac...so that will help some...
Old 04-05-2009, 08:15 PM
SUPERBOOST's Avatar
You can fit the stock radiator in with puller fans.You have to drop it down about 1.50-2.00 inches and move it foward,the further the better.You will have to cut out the sides of the radiator support and replate them when you get clearence for the radiator.Do a 1or1.5 inch tube across the top and make a plate bolted to that to hold the top of the radiator where you want it.Cut the bottom radiator support out and move it down and you can even use the factory radiator supports.It will take a little looking to find the right fans for your setup,but use the biggest ones you can fit.
Old 04-05-2009, 08:24 PM
MECHAM's Avatar
stock radiator...stock fans ST80 in the front
0 (zero) overheating...
Old 04-05-2009, 08:34 PM
Restricted User
98Z28CobraKiller's Avatar
I will be running the stock replacement SLP with 3 cores. Stood up, moved up and dropped. You can see it from post #51 on in my build thread.
https://ls1tech.com/forums/forced-in...-w-pics-3.html
Old 04-06-2009, 12:37 PM
cjg454ss's Avatar
i tried all 4 option.,
stock radiator and stock fans. = perfect ran a 190*
griffin 15x27 stood up w 16inch spal ran- 250*
griffin 19x27 stood up w 16inch spal and 14inch pusher- 200*-210*
griffin 19X27 with stock fans= 160*(icey cold)
my conclusion is you need the air flow most importantly. if you have 400 bucks to spend lets say, 300 for fan and 100 for a radiator with be better than a 300 buck radiator and 100 fan. trust me i know from experience,
flat black engine bay
Old 04-06-2009, 03:49 PM
Thanks for the input cjg454ss... Do you have any pics of the stock rad and fans set-up? Anything in particular I need to watch out for? I assume you tucked it all the way up and modded the lower mount to drop it as well? I would really like to use my stock set-up just for reliable cooling of the stock fans etc.
Old 04-06-2009, 09:31 PM
cjg454ss's Avatar
yeah just remake the bottom bracket for the radiator. keep it angled and you will be fine.
Old 04-06-2009, 11:11 PM
Lose the washer tank or can it be saved with stock set-up?...
Old 04-07-2009, 06:40 AM
cjg454ss's Avatar
i had to ditch mine. i later ditched my wipers and will be ditching my wiper motor for some weight saving. you probably could save the wiper tank but really you could just get a smaller one and mount it anywhere,
Old 04-23-2009, 02:15 PM
Any major clearance issue with running the stock rad tilted and brought forward? I cant imagine the rad will sit any lower than the IC pipes etc...
Old 05-27-2009, 05:33 PM
Vetal's Avatar
I have read that it is possible, and I planned to do that, but today I just couldn't see how to fit it - it is about 5mm wider than would fit between metal supports going up from the rails... Can someone explain that? I think these "towers" hold also headlights, and I do not want to cut them
Maybe someone has good pics?
Old 05-27-2009, 07:28 PM
Vetal's Avatar
Anyone? Does it really fit in width?
Old 05-27-2009, 08:07 PM
dudeman's Avatar
i would like to see pics of the front mount turbo with stock fans!!!!
Old 05-28-2009, 09:11 PM
SUPERBOOST's Avatar
The stock radiator will not fit moved forward without widening the opening in the core support.You cut the sides of the core support out to where you need them and then build new side plates out of sheet metal and weld them in.You have to drop the radiator down about 1.50 inch.You can do this without affecting your headlights.You can leave part or all the top of the core support but it gives you more room to cut it out and replace it with a piece of square tube moved to the front of the opening,like in cjg454ss's pictures.
Old 05-29-2009, 01:00 AM
That sounds good to me!! Pics would be awesome!!
Quick Reply: Who runs stock radiator?
