What lid for 85mm maf and stock TB?
Just finished putting an lm7 in my 99 v6 camaro. Im using the stock 85mm truck MAF (came with the motor) and the stock 78(or whatever it is) TB. On the v8 cars my understanding is that the maf goes in the end of the lid then a couplling to the TB? If so what size lid do I want? I know the ftp is actually bigger than 85.
Help me out guys!
Help me out guys!
Ft 85!
If you are using the 85mm Truck MAF the FT 85mm LID will allow the MAF to slide right in with no coupler required!
If you are just using a stock sized LS1 Fbody MAF, you can still use the FT lid but you need to purchase the adapter for 8.00 additional.
Cool swap!
Cool swap!
No it is just a minor rubbing problem so it will not damage the lid. They are 146.99 shipped. If you need the coupler for a stock sized MAF, it is an additional 8.00
Thanks
Thanks
