what sensers tell the PCM to shift?
Old 04-07-2009, 09:48 AM
95formulalt1's Avatar
Default what sensers tell the PCM to shift?
what sensers tell the PCM to shift??
Old 04-07-2009, 10:37 AM
marors1's Avatar
I believe it depends on throttle position, MPH and RPM. A mixture of those three will tell the PCM when to shift the transmission.
I believe that it normally shifts on throttle position/mph, and uses RPM for WOT shifting if I remember right.
D
Old 04-07-2009, 03:34 PM
im talking about the TPS MAF stuff like that
Old 04-07-2009, 07:10 PM
Gary Z's Avatar
Your question is carelessly worded. No sensors "tell" the pcm to shift. The TPS only tells the pcm throttle position. The VSS sensor only tells the pcm vehicle speed. The pcm derives engine speed from the crankshaft position (CPK) sensor. The pcm uses information from different sensors (TPS, VSS, CPK) under different conditions to decide when to tell the transmission to shift. As far as I know, TPS, VSS and RPM (maybe MAP) are the main inputs involved.
Old 04-07-2009, 08:41 PM
joecar's Avatar
What problem are you seeing...?
Old 04-07-2009, 10:09 PM
wont down shift at WOT. and is shifting at 2-3k rpms. its not the tranny cuz its new and it did this with the old one which works great in another car.
Old 04-07-2009, 10:20 PM
joecar's Avatar
Check the following for correct operation/DTC's:
TPS
VSS
Old 04-08-2009, 08:25 AM
whats the VSS?
Old 04-08-2009, 10:17 PM
Orangemagic's Avatar
Vehicle Speed Sensor "VSS"
