racetronix pump gone bad(broke bucket)
well i put the silicone grease they supplied on oring as stated and it was vert slippery couldnt get it in the hole it goes into.. so i took o-ring off. slid in fine, so i thought a lil more pressure would bt fine since it fit without oring
nope, cracked the side where it slides into...
what should i do????
i dont think i wanna hunt for a new bucket.
it fits alright in the bucket but the oring is not doing its job of sealing now... should i leave it and make sure pump cant go up and down and its secure..
or just delete bucket?
http://www.geocities.com/formulapowe...fuelpump17.jpg
the pump has a oring on it at the bottom and slides into that
Ok, thats why it is different. Might want to include what kind of car you are talking about in future posts since you don't have a car in your signature. Helps keep confusion down. As far as the problem I really can't say since I don't have any experience with the fuel bucket on an LT1 and how its setup. I would say the best bet would be find another fuel bucket but maybe you can just delete the bucket altogether.
I have a 97, I'll give it a shot. First, on mine, I had to Dremel out those 3 ridges on the inside circle where the bottom of the pump slips into. A pita to reach, but it allowed me to slip the pump down in there.
Second, do you have a close up of the actual crack? Your bucket consists of two parts; the top which you did not show, and the bottom part of the bucket (which I consider the actual bucket). The bottom part of the bucket has two main functions: The small circle inside at the botom guides the pump intake into it so it can draw fuel through the fuel sock. It second function is to stay relatively full of fuel so it can cool the pump.
So, where is the crack that you mentioned? It may actually be in the pic, but it's 4 in the morning here so I might be missing it. lmk.
Personally, I would not suggest going bucketless on our vehicles. Too much risk for overheating the pump. JMO.
So it sounds like you have two options:
1) Try to find a sealant that is impervious to gasoline and seal the crack. Outside my area of expertise.
2) Try to find another bucket. Best of luck on that one, I have been trying for months with no success.
Sorry, wish I could offer more help.
