What length PR with PRC 59cc heads?
Anyone else running PRC 2.5 heads milled to 59cc and a TR224 cam? What size PR should I be lookin gto run with this setup? Here are all the details.
TSP PRC 59cc milled heads
LS7 lifters
TR224 cam on 114
Replacement stock GM head gaskets
I currently have aftermarket hardened stock PR in there, do I have to wait til everything is ripped apart to check what length I will need and then order or is anyone running this setup?
Thanks
LS7 lifters
TR224 cam on 114
Thanks
I am going to measure but here is the deal. I'd like to get a rough idea of what length others with my setuo are using, so that when I order the PR length checking kit, I can also order a set that will most likely match my setup so I have them instead of ordering twice and waiting 4-5 days twice to get them from TSP. If they aren't what I need I can always send them back. Currently I have the 7.4 hardened rods in there and I'm guessing they aren't going to work. Is it a good bet that if anything I'm going to need shorter PR then 7.4?
LS1Tech Premium Sponsor
Responded to your PM, but forgot to ask what part number was on the Comp package you received. We only stock one pushrod length checker PN typically, and I just want to rule out the chance that you got the wrong one! Let me know.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Sorry Comp sent us the wrong pushrod checkers, but no worry I had my guys eat a little bit of overnight to get the correct checker to you asap. We always try to take good care of the customer even when the manufacturers mess us around!!
Definately need to get the correct pushrod checker. My bet is 7.350" will work, but a little bit of checking can go a long way. Don't worry it'll be worth the wait...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Sounds like a plan, Fran! (sorry, had to do it).
Let us know how it goes!
__________________
Nice! Not bad for a relatively small camshaft and budget oriented heads! Should be a fun ride for Richard!
__________________
