What length PR with PRC 59cc heads?
TSP PRC 59cc milled heads
LS7 lifters
TR224 cam on 114
Replacement stock GM head gaskets
I currently have aftermarket hardened stock PR in there, do I have to wait til everything is ripped apart to check what length I will need and then order or is anyone running this setup?
Thanks
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Definately need to get the correct pushrod checker. My bet is 7.350" will work, but a little bit of checking can go a long way. Don't worry it'll be worth the wait...
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
7.350 worked good jason. We will be dynoing the car later today. We did a similar set up a few weeks ago with those heads and they made great power for the set up.
Let us know how it goes!
