L92 stroker not working properly
Old 04-10-2009, 09:57 PM
jose de la paz's Avatar
Default L92 stroker not working properly
when you look at the dyno graph you'll see that the horsepower hangs from 5300 to 6600. I've seen other dyno graphs that pull to 6100 and then start to come down. one the first pulls the throttle body was only opening three quarters of the way. once we fixed that it only picked up 10ftlbs of torque, horse power remand identical and again hung from 5300 to 6600.
The motor has
ported L76
L92 west coast cylinder heads
HK engines 418ci
Kooks long tube headers
90mm nick williams
Any help will be appreciated
thanks,
/Users/josedelapaz/Downloads/JOSE_DE_LA_PAZ.bmp
Old 04-10-2009, 10:13 PM
malibutwins's Avatar
maybe you intake manifold?
Old 04-10-2009, 10:31 PM
going to order new one and see what it will do and if not then it will have to be a carb intake . this is crazy.
Old 04-11-2009, 07:44 AM
jleews6's Avatar
I cant see the dyno sheet but,What cam do you have?
Old 04-11-2009, 11:01 AM
the cam 238/250-115+3/Users/josedelapaz/Downloads/JOSE_DE_LA_PAZ-1.bmp
Old 04-11-2009, 11:10 AM
cant seem to be able to post the graph
how images and enable links: for this message | always for this sender
(No subject) Print | New Window ***** Diaz to you - Mar 24 More Details Add to: To Do, Calendar JOSE_DE_LA_PAZ.bmp
Old 04-11-2009, 12:31 PM
Old 04-11-2009, 03:07 PM
rotary1307cc's Avatar
You are making some nice #'s as is through a mustang
Old 04-11-2009, 03:16 PM
xpndbl3's Avatar
intake manifold limited, get a vic jr on there IMO
Old 04-11-2009, 03:31 PM
i think a carb style will kill the bottom end. the only other one out there is the fast. but its a lot of money to find out its not the problem. damn those gremlins.
Old 04-11-2009, 03:36 PM
KingSS's Avatar
what kind of lifters?
Old 04-11-2009, 03:37 PM
its making power but it should pull to 6100. not so worried about the numbers just want it to run right. looks like its going to cost a lot to find out whats wrong.
Old 04-11-2009, 03:40 PM
lifters are LS7
Old 04-11-2009, 08:52 PM
WKMCD's Avatar
Not lovin' that cam but what is your CR?
Old 04-12-2009, 07:25 AM
BAMF's Avatar
You need a better intake and a different cam
Old 04-12-2009, 08:11 AM
SweetS10V8's Avatar
Valvetrain issues possibly?
What cam, springs, pushrods, and rockers are you running?
Old 04-12-2009, 02:45 PM
CR 11.3 to 1. spoke with richard at west coast cyl. seems like air restriction. he thinks its the intake. well soon see.
Old 04-12-2009, 02:49 PM
WKMCD was your intake ported. mine is, dont know if it could have been damage during the port work.
Old 04-12-2009, 03:09 PM
THENASCAR's Avatar
i was thinking the same thing. having valve float problems? intake definatly, could be a number of things
Old 04-12-2009, 07:51 PM
was talking to erik and richard. they dont think it is a valve train issue because its to stable.
Quick Reply: L92 stroker not working properly
