Pulled the intake and found this....
Old 10-26-2003, 12:04 PM
NataSS Inc's Avatar
Default Pulled the intake and found this....
I have posted a couple times concerning coolant mysteriously dissapearing, smelling it in the exauhst, but no white smoke, no leaks of any kind, nothing. Well I pulled the intake off the other day and found this in #7 intake port.
Any idea what caused this. Some have said it is bad head gasket with a small enough crack to be a pain in the ***. But with a cracked gasket how does oil get thrown all the way through the intake to #7 and NONE of the others?
Old 10-26-2003, 01:07 PM
ta12sec's Avatar
What does your oil look like?
Old 10-26-2003, 01:08 PM
Scalpel's Avatar
Maybe the porting process damage the head on that area?
Old 10-26-2003, 01:23 PM
LS1TECH Sponsor
mikey's Avatar
I've seen this before. That intake port is leaking coolant. Do a coolant pressure test and you will see it bubble out on the side of the port. Basically, that head is scrap.
Mikey
Old 10-26-2003, 08:17 PM
Scalpel's Avatar
Mikey
That's what I was afraid of. That makes me want to vomit Those heads are high $$
Old 10-26-2003, 08:27 PM
SSactionLs1's Avatar
goto who did em and have words/fists...and if they dont help you then tell us who it was and they wont get any business from ls1tech
Old 10-26-2003, 09:38 PM
NiceTry's Avatar
lol have fun stopping everyone from going to MTI
Old 10-26-2003, 10:04 PM
LS1Tech Sponsor
Slowhawk's Avatar
YUP,it's a cracked intake port.Happened to me on one of my LS6 Heads.Same exact problem(coolant dissapearing)Ended up being a crack on the short side of the port.
MTI should 100% warrenty the Head without question.They will probly try to blame a air pocket of causing it.
Old 10-26-2003, 10:10 PM
Vendetta's Avatar
that suuucks... look on the bright side, at least your sure of what the problem is.
Old 10-26-2003, 11:00 PM
jmX
jmX's Avatar
Guys, that kinda stuff happens sometimes, this isnt the first time. They can fix that head no problem, it isn't scrap. Unfortunatly it means you'll be without a head for a bit, but the upside is you'll get the head back and you'll now no longer have to wonder where your coolant went.
Old 10-27-2003, 12:10 AM
eh...i dont owe em any money
Old 10-27-2003, 01:25 AM
NataSS Inc's Avatar
Well I will pop the head off the car this week and get it pressure tested. If it is cracked I will send it back to MTI.
One thing I forgot to mention. There is also oil in the #7 intake runner and only in the #7. And the same junk thats in both of those places is also in the PCV as well. When I went to pull the intake I notcied 2 small drops of that residue right under the PCV. So I pulled it out and stuck my finger in it and it was covered with that same crap.
Old 10-27-2003, 02:05 AM
4thGENRETARD's Avatar
Send an e-mail with this pick to Jason. I don't think he won't back up his work. MTI is very straight on that.
Old 10-27-2003, 06:25 AM
2000RATA's Avatar
Seems to me there might be 2 problems. 1 is your coolant leak. The other is the oil. Look VERY closely to the upper corners of that intake runner just inside the port. The LS6 heads are VERY thin there. Those ports looks plenty wide and would make me suspicious of them breaking through in the the rocker arm area. Look in the very corner of the rocker arm boss, between the intake side and the rocker arm boss by the pushrod with rocker arm cover off ofcourse. Then on the exact opposite side. It can be welded and you'll be fine if there is a hole. But it can't be pressure tested. You will just have to see it to find it.
Old 10-27-2003, 09:27 AM
LS1Tech Co-Founder
Nine Ball's Avatar
"That head is scrap"??? Come on Mikey, as a shop owner I'd have expected a more realistic answer. These heads are aluminum and can easily be welded up and refinished. Repairing a port-thru crack is very simple, and very common. I've literally torn up a combustion chamber when a piston came apart, and it was very simple to weld back up and finish. You couldn't even tell the damaged chamber apart from the others when it was done.
Tony
Old 10-27-2003, 09:50 AM
Scalpel's Avatar
I'm sure MTI will stand behind the head. At least you know what the issue is now.
Old 10-27-2003, 12:00 PM
robertbartsch's Avatar
Yeh, this can and does happen....but....
...Since the head was shipped with a defect, the deller should send him a new head, plus $ parts and labor...
Old 10-27-2003, 12:29 PM
Scalpel's Avatar
No vendor/tuner/seller ever provides money reimbursement for labor unless they perform the work. At least with the ones I have seen.
Old 10-27-2003, 12:33 PM
I'm not sure why you should subscribe to the notion that "this stuff happens...." ...you paid full value and received a head that is defective....
I would expect the seller to replace the head with a new unit and pay for parts and labor to swap the bad one out...
Old 10-27-2003, 12:45 PM
Scalpel's Avatar
I wasn't subscribing to that notion. MTI will warranty the defective part, the head (assuming it was bought new through them or through a supply vendor, if it was bought second hand, I doubt they would), I don't have a doubt about that.
I'm saying that shops that make/sell a product never re-imburse the consumer the labor and/or extra parts (gaskets,etc) needed to for the job unless they (the company that sold/installs it) performs the repair. If you're a remote buyer and order your stuff and have it shipped to you and have it installed you're NOT going to be reimbursed for the labor another shop/person did. That's just the way it is. I have never seen a shop/tuner/vendor prove me otherwise.
