2002 ls1 coolant odor
Old 04-12-2009, 11:33 PM
MICAH HERRON's Avatar
Location: Johnsonville, SC; but orginally from GAINESVILLE, FL
Default 2002 ls1 coolant odor
Wasn't sure where to post this on the forum, so I am posting here.
About a month ago I started noticing the distinct odor of coolant. It wasn't often and nothing visible. Well, one afternoon after sitting in the traffic I parked my car and noticed the overflow of coolant dripping from the left handside of my car, just under the radiator. I popped the hood and noticed that it was coming from the overflow hose that comes out from under the cap. I allowed the car to cool, checked the level and it was fine/full, however I noticed flakes in the coolant, so I had the system flushed the next day. I still noticed the smell and it has been a couple of weeks. The coolant level is still the same and the temp doesn't go above 210 at the hottest.
Any ideas?
Micah
Old 04-13-2009, 05:40 PM
Moderator
davered00ss's Avatar
Moved to General Repair & Maintenance.
Old 04-14-2009, 12:02 AM
sroach20's Avatar
change your radiator cap, it can allow the steam to escape without much loss of coolant. when is the last time you changed your cap?
Old 04-14-2009, 12:05 AM
Speed_Freak6's Avatar
You could have a hole in the hose? If the radiator cap wasn't sealing you would see more coolant than just a drip.
Old 04-14-2009, 12:25 AM
sroach20's Avatar
not true, i barely had any seepage and could see steam coming out. i put on a stant and the smell went away.
Old 04-14-2009, 09:53 AM
I thought about this too. The car is stock, and I have only had it a little more than a year now, so I am going to look into that.
Old 04-14-2009, 10:05 AM
sroach20's Avatar
make sure you get a stant!
Old 04-15-2009, 01:26 AM
Well, it was getting bad this morning so I had a shop look at it. I couldn't get the time right away, because I am getting ready to deploy and it turned out to be the water pump was leaking by. That hit the wallet pretty good.
Old 04-15-2009, 05:58 PM
pacdwal02's Avatar
How much did the new water pump cost?
Old 04-15-2009, 10:59 PM
Well, I am in Hawaii, so prices are a bit inflated. The price for the pump was $265. I am certain you can find it on the mainland for less.
Old 04-17-2009, 03:52 AM
Ironxcross's Avatar
threadjacker here:
what is a stant?
Old 04-17-2009, 08:28 AM
sroach20's Avatar
they make radiator caps, gas caps, etc....
Quick Reply: 2002 ls1 coolant odor
