347+Novi 2000+14.4lbs===831rwhp
Old 04-13-2009, 11:08 PM
Closed ex-Sponsor Account
sho-me speed's Avatar
Default 347+Novi 2000+14.4lbs===831rwhp
Well I got the Z06 to the dyno today with the new set-up and I was pleased with the results.
It is the following (Motor built by Eagle Machine):
LS6 Block, 347c.i
Stock Crank,
Diamond Pistons,
Callies Rods,
ARP Main/Head Studs,
TEA LS6 Heads,
Cam Motion Custom Cam,
Typhoon 85mm Intake,
Novi 2000 with stock balancer and 3.3 Pulley,
Motron 60lbers,
Alky Control Meth Dual Nozzle Kit,
MSD Boost-A-Pump,
Racetronix Hotwire Kit,
Tuned By Me
-----Made 638 to the wheels on 8.5lbs
-----Made 831 to the wheels on 14.4lbs
Old 04-14-2009, 02:45 AM
Spectre86's Avatar
sounds like a wicked ride. any videos?
Old 04-14-2009, 09:21 AM
bad95killer's Avatar
Very impressive results man
peace
Old 04-14-2009, 10:53 AM
allngn_c5's Avatar
Awesome results !!
One question, is the 13.6 you a/f ratio ?? If so isn't that way to lean for FI ?? You might even pick up more power if you add some fuel.
alharbi's Avatar
peace
+1
any vids. ?
Old 04-14-2009, 10:55 AM
alharbi's Avatar
i agree
Old 04-14-2009, 12:12 PM
Originally Posted by alharbi
i agree
Thier widebands at the tailpipes were consistently reading .7 leaner than mine right after the collector and were are using the exact same widebands.
It spiked to around 12.9 right at the end of the run. It was 11.5 or so the whole run until right at where I let out.
I maxed out the injectors so that is where we stopped. If you look closely at the line it is very flat the whole way and then you can see it swoop up right at the very end
Old 04-14-2009, 12:34 PM
LS1RedZ's Avatar
Wow! Those are some awesome numbers with a 347!
Old 04-14-2009, 08:18 PM
Gordon0652's Avatar
How did you make "Made 638 to the wheels on 8.5lbs"? Racegas?
Old 04-14-2009, 08:34 PM
NOPE. 93 octane and 18 degrees of timing.
Old 04-14-2009, 10:01 PM
Abdullah's Avatar
very strong numbers specialy with the 60lb injectors. great power.
Old 04-14-2009, 10:04 PM
Abdullah's Avatar
btw, how do you compare the novi 2000 to the procharger D1 SC? which is more streetable and will make more torque at the low end or i mean will be more suited for the street?
Old 04-15-2009, 10:46 AM
The NOVI has a 3.54:1 ratio and the D1SC is a 4.1:1 Not sure if that helps answer your question. The best way is to look at the compressor mapsa for the efficiency range.
Old 04-15-2009, 01:45 PM
WickedC5's Avatar
Any chance you can share the cam specs? or are they ?
Old 04-15-2009, 01:59 PM
Bville99gt's Avatar
WOW!! seems like a very simple setup yet very effective. Congrats!!
Old 04-15-2009, 08:27 PM
232/242 .61x/.61x LSA116
Old 04-18-2009, 12:24 AM
WickedC5's Avatar
Thanks!
Old 04-18-2009, 11:12 AM
o2ws8's Avatar
Damn sick numbers dude!Post some vids!
Old 04-19-2009, 09:07 AM
venom ws7's Avatar
Congrats man thats awesome
what si the compresstion of the engine??
what fuel did you use with 831rwhp run??
video video video
Old 04-21-2009, 12:07 AM
video video video
11.3:1
93 Octane and Meth
I will have track video soon hopefully.
Quick Reply: 347+Novi 2000+14.4lbs===831rwhp
