Valve Spring Question
I'm fixing to install an APS TT kit on my 2000 trans am.
I'm considering adding an LS6 cam.
I know the Valve springs need upgrading will the LS6 springs be enough or will i need to go bigger/better?
Thanks
Steve
Thanks
Steve
11Second Club
If you're running boost, you shouldn't use stock springs. You're going to want something with more seat pressure. I'm sure someone will recommend the Patriot dual golds.
How much boost will you be running? I am running the stock 7psi and the LS6 valvesprings are working great on my set-up. If I ever up the boost, a stronger spring would be needed. But I was told these are fine for the low boost. And so far they have been. Over 15k on my kit since it was installed in Fall 2007. I DD it in the warm weather and take it on roadtrips. Drive it to the carclub track rentals and play for the day. So they have seen all kinds of usage.
