SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies
Old 04-16-2009, 08:11 AM
SPEC-01's Avatar
Default SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies
SPEC, Inc Clutches and Flywheels introduces their Super-Twin for street and track use in the LS9 Corvette ZR1. SPEC also offers Super Twin fitments for LS9 to T56 conversion applications.
Until now, there has been a drivability, maintenance and longevity trade-off with clutches built to handle 700-1700 ft.-lbs. tq. The revolutionary new SPEC Super Twin has set a new standard by offering near-stock drivability, tremendous life expectancy, bolt-in installation with no shimming or setup needed and maintenance free operation. These units are upgradeable, downgradeable and rebuildable for ultimate versatility.
SPEC Super-Twin's are constructed with aircraft grade aluminum and high carbon billet steel milled to an industry leading .001 inch for perfect balance and actuation. All billet construction allows these units to be smooth and quiet in operation. Friction is provided by one of four disc types ranging a Hybrid Kevlar/Carbon Graphite Puck to full-metallic (Sintered Iron) option.
Torque capacities upwards of 1700 ft.-lbs. can be realized depending on the disc type specified. Flywheel and track-spec hardware are included in each kit.
Pricing for the SC10 Series Super-Twin is:
SC10SST $1549
SC10PT $1749
SC10ST $2049
SC10ET $2149
To find a SPEC distributor in your area, call 205-491-8581 or visit www.specclutch.com.
Attached Thumbnails SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies-spec_logo_web.jpg   SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies-spec-web-super-twin-2.jpg
Old 04-16-2009, 10:50 AM
jw33's Avatar
It would be nice if someone could make an aluminum flywheel that bolts up to the more common LS1/2/3/7 six-bolt crankshaft, but allows the use of the LS9 GM twin disc setup.
Old 04-16-2009, 10:56 AM
why me's Avatar
^^^ just fill in the holes and make new holes.
Old 04-16-2009, 10:58 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Hard to do with cast iron.
Andrew
Old 04-16-2009, 11:04 AM
SPEC-01's Avatar
Also hard to do when the geometry of the kits is completely different. The LS9 flywheel is almost 3 times thicker than the LS1 flywheel and thus the total geometry, along with the difference in crank pattern, would not allow you to take an stock LS9 part and istall is into your LS1/T56 car.
Old 04-16-2009, 11:50 AM
jw33's Avatar
I'd love to see some pictures of the LS9 flywheel/clutch next to the LS1/2/3/7 or just the LS9 by itself.
Old 04-16-2009, 02:09 PM
SPEC-01's Avatar
Let me see if I can get some pics of this for you. Thanks,
Old 04-16-2009, 03:53 PM
SNLPerformance's Avatar
It would be even better if it were that simple.
Exactly!
If you can't find them Jeremy I've got three setting here, I'll be more than happy to get those pics for you. Nice multi-disc btw, very nice!
Old 04-16-2009, 04:04 PM
What geometry are you guys talking about?
Andrew
Old 04-17-2009, 11:24 AM
SPEC-01's Avatar
I am referencing the difference in stack-height. This is the distance from the crank-mounting surface on the rear of the flywheel to the diaphragm finger peak. The LS9 clutch assembly is not like anything else used by GM in the Vette or Camaro in the past. I haven't had time to get the pics...it has been wild around here this week. But I will try to get them posted shortly. Or SNL can post them too...as stock parts are stock parts! Thanks for the complements on the kit by the way. Let me know if you guys need anything else. Thanks,
Old 04-17-2009, 01:29 PM
If I remember correctly the stack height is roughly 1" taller than the LS1 stuff. Here is a pic of the assembly, I'll get some time to do a side by side comparo next to a Monster Level 3.
Old 04-17-2009, 04:50 PM
jw33's Avatar
Hmmmm, so some type of shorter slave cyl would have to be used and you may still have problems with the disc(s) engaging the input shaft on the tranny......
Old 04-20-2009, 08:36 AM
SPEC-01's Avatar
As well as a flywheel with the correct crank-pattern for your application.
Old 04-20-2009, 04:46 PM
Yup, already made on.
The damn slave is the problem, there just isn't enough room in the bellhousing to get this thing to work... it makes a really nice paper weight though. LOL
Old 04-21-2009, 08:59 AM
SPEC-01's Avatar
Yep...room limitations are a major factor. Of course...having seen the stock ZR1 part and knowing that it utilizes an organic disc material...I don't think that it is as ideal as many believe it to be. Remember, organic discs, especially those using a marcel spring, will have a tenency to compress and this can greatly affect the clutches engagement point and long-term durability.
I know that there will always be those that want to use alternative OE options on their cars because "OE parts are great"...but in many instances there are better, more durable, higher capacity options available from aftermarket manufactures that offer a better value to boot. I know...I am biased...but I am also speaking from experience and as an enthusiast. Let me know if you all have any further questions. Thanks,
Old 04-21-2009, 11:18 AM
LOL, LS7 *cough*cough*
I know what you mean, organic material with a coefficient of .25 is no match for a cerametallic material with a .38... it is what it is though, some will never agree with us.
Old 04-21-2009, 01:38 PM
jw33's Avatar
Well I can see where you guys are coming from because you both sell a direct replacement for what we're now talking about. And I'm sure your companies both sell a good product. That being said, us normal guys sometimes like the feeling we get from an OEM part and also the fact that they are a great value in most people's opinion.
Old 04-21-2009, 03:09 PM
slow's Avatar
I've tried your "better, more durable, higher capacity options", got poor life out of it, barely held the first time shifted at wot with a stockish ls1(with 8K street miles as breakin) and went back to a LS7 clutch when it completely wore out.
Ryan
Old 04-21-2009, 11:28 PM
racecar's Avatar
That LS9 looks like it must weight 100 lb. What is the actual weight of the whole assy?
What's the diameter of the discs??
Old 04-22-2009, 09:33 AM
SPEC-01's Avatar
Slow...I hate that you were unhappy with the part you purchased. I do not remember talking with you about this...of course I am not sure of the timeframe since purchase or any other details...and as you can imagine I talk to hundreds of people each day (with the great majority being quite pleased with the products we provide). Did you request an RMA and subsequently send the unit back to us for assessment?
Quick Reply: SPEC LS9/ZR-1 Super Twin Billet Multidisc Clutch and Flywheel Assemblies
