cam suggestion for a stealth setup
Old 04-16-2009, 09:57 PM
eric01ss's Avatar
Default cam suggestion for a stealth setup
want a sleeper cam
will be for a a4 car with a 3600-4000 stall
also will have full exhaust and up to a 150 shot
Old 04-16-2009, 10:17 PM
sunsetorang01TA's Avatar
224R cam with the sleeper idle (116 LSA) from TSP. would be perfect for a stall setup closer to 3600.
Old 04-17-2009, 03:21 AM
PREDATOR-Z's Avatar
What do you mean by full exhaust?
Old 04-17-2009, 03:26 AM
PREDATOR-Z's Avatar
218/230 .605/.604 117+4 LSA
Custom, 42 IVC, -10* overlap, exhaust biased >> Stealth and likes juice
Old 04-17-2009, 05:20 PM
eric01ss's Avatar
full exhaust will be long tubes into 3inch true duals predator
Old 04-17-2009, 05:29 PM
01Z0H6's Avatar
Running a similar set up Eric.. Lanes 3in TD's running into my 3in CME, Vig3600 stall..
Not a "stealthy" cam.. G5X3.. made 417/386 to the wheels..You can definately hear mine... GL..
Old 04-17-2009, 05:49 PM
98TA6.0's Avatar
how bout an LS6 cam, 1.8 rockers, and ALOT of N2O? that's pretty stealthy huh? lol
Old 04-17-2009, 06:40 PM
PREDATOR-Z's Avatar
That is hardly Stealthy don't you think. Like you are asking a contradiction in terms.
Then I would revise my choice to 224/224 .609/.581 114+2 LSA
Old 04-17-2009, 07:02 PM
eric01ss's Avatar
pm sent predator!
just dont want a lopey cam
Old 04-18-2009, 03:07 AM
98TA6.0's Avatar
who says you cant use a stock cam and get what you want? there are guys in the 10s with stock cams. Heads make or break the motor. i'd say a serious set of heads and an LS6 cam with 1.8 rockers. you can make big numbers that way. big cams only put the power band higher up anyway.
Old 04-18-2009, 03:24 AM
goober35's Avatar
GT2-3 cam is a sleeper cam.
I loved my 228 cam on a 114 lsa. It did not lope at all.
Old 04-18-2009, 02:54 PM
JPH
JPH's Avatar
Perfect. But add 4* more to both sides on XER lobes with that stall, and let it eat!
Old 04-18-2009, 03:29 PM
TurdsOfMayhem's Avatar
I would like to hear a 'stealthy' setup. This is what I have been planning to do with my bird.
Old 04-18-2009, 05:53 PM
YankeeVert.'s Avatar
I have a stealth cam.No lope,650 RPM idle : 218/224/.605/.581 115+3
