Noisy valvetrain, time to upgrade.
Nothing has been done to my engine so I figured I should. What do you guys think of this combo.
xr269hr-14 cam with supporting springs, pushrods.
Ls6 intake
Probably a new oil pump and timing chain as well.
I figure these two changes will compliment the full exhaust nicely. I'm looking for another 30hp or so. I am really pleased with the performance now but everyone wants a little more. I would like to keep the 2.73 gears.
Again, i'm not looking for 450hp cause I don't won't to blow up my tranny/rear, this is my 2.73 geared summer driver.
Ls6 intake
LS1Tech Sponsor
How about some GTP ported 241s with ls6 springs and stainless valves $800 shipped for the pair? i can get you set up with the ls6 pump as well and an ls2 or jwis chain, head gaskets, bolts, the whole number for a package price. I can also get you fixed up with the cam, pushords if you want them, and the ls6 intake.
LS1Tech Sponsor
http://www.sdparts.com/product/GTP24...nderHeads.aspx
flow sheet is on the page there
and im assuming on the cam its a comp cams xr269hr type.
prob 216/220 525/532 114...but i might be a little off. seems like a reasonable guess
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.525 0.532
Duration At 0.006 Tappet Lift 269 273
Valve Timing At 0.006
Open Close
Intake 23 66
Exhaust 73 20
These Specs Are For The Cam Installed At 112 Intake CL
Intake Exhaust
Duration At 0.05 216 220
Lobe Lift 0.309 0.313
Lobe Separation 114
Those are the specs. Should I go with a LS6 type cam instead?
Open Close
Intake 23 66
Exhaust 73 20
Intake Exhaust
Lobe Separation 114
Not sure it would be worth the work for the small gain on that cam. Go with a 224 if you want a little cam, lots of happy people with it! It sounds like you have some modest goals, you could possibly get close with just the intake and a tune. If you do have the front cover off, silly not to change the pump and chain. They are not expensive.
Yep there is a number of us with just cam's and Full exshaust and LS6 intakes that still have stock heads that run 12''s and if you cant get to the high 12's a full nitrous kit shipped is $422 from harris speed to your door. That imo is the best mod. Cheap and effective!
