SES light and car sputters
I've been a member here for years but can't get the password to work but anyways my car isn't running good as usual. Since I started driving it I have been having issues with getting on the gas and the car sputters off an on. It does it full throttle and also just regular crusin. Also the SES light flashes for around 5 seconds. Also the exuast makes a funny thumping sound which I never heard before So I hooked a ODB test too it and got code P.1133: Manufaturer Control Fuel Air Metering. I believe this is my O2s from searching but not sure. I have Kooks longtubes and catted Y pipe for about 4 or 5 years. I have had the SES light every year go off an on but it never made the car run like this. What could be the problem and a remedy for it? Would unhooking the battery maybe fix this?
I don't have my ODBII book around, but I think that is the insufficient O2 switching code for bank 1.
I'm guessing you have a bad forward O2 sensor on the drivers side. I'm also guessing that the car is running discusting lean on one bank, hence the hesitation, exhaust popping and misfires (indicated by the flashing SES).
yeah its the the H02S insufficient switching bank 1 sensor 1. Have you done anything to the car recently before you started having this problem, check wiring, pull out the 02 and see if it is in good shape.
I haven't done no mods for a few years. It sits during the winter and the battery died so I got the car started and left it run for 20 min. I have longtubes and catted y,slp airbox and slp maf mods done to the car.
I switched the front driver side O2 sensor. The ses light is still on and it still misfires and sputters. I noticed when turning the car on the exhaust sounds normal (evden after heated up) but after like 30sec its starts to make the sound again that kinda reminds me of popcorn or something. Does the car need to tune itself again? I only drove it 10 miles since the swap today.
Sounds like the problem is coming into play when it switches to closed loop - which happens in less then a minute after first starting the car.
In closed loop the car begins to reference the O2 sensors for fueling.
Try unplugging the front two O2 sensors and see if he car runs without the misfires. This will hold it in open loop (not referenceing O2 sensors). If the running cleans up then the problem is isolated to one or both of the front O2 sensors or related wiring.
Did you try unplugging the front two on both banks?
All black just means the car is running overly rich....or poor combustion. It just backs up what was suspected: the a/f of the car is not correct.
You need the O2 sensors to pass emissions.
I wouldn't get rid of the O2 sensors. I still think the problem has something to do with one of your two O2 sensors or associated wiring.
Unplugging both front O2's for a little test will confirm it.
Once you find the issue, the fuel mixture and such will come back into line.
I unhooked both O2 sensors and the car doesn't have the misfire while sitting. I took it for a short ride and it seemed good. I want to take it for a further ride though to see if the problem is gone. Whats my next step if it runs fine with them unhooked?
I've had the same problem a few years ago. Your best bet is to get new o2's. I would recommend Denso's. I just bought a pair of them. Many guys from the board here like them. Either that or you can run open loop all the time. I did it for over a year an a half. I'm sick of it now though. Your car will def run alittle richer and lose gas milage. Good Luck.
I had the car out and it started to misfire and sputter again without the front o2s hooked up. So I'm guessing thats not the problem now. Could it be either my fuel filter,spark plugs of MAF causing this or any other ideas? It most noticable when in overdrive and tapping the gas or if ASR comes on and car shifts into second and trying to accerate.
