help car still dies...
Old 04-19-2009, 02:51 PM
ihaterice's Avatar
Exclamation help car still dies...
just got done replacing the icm and i am having the same problem still. the car will just shut off after about 20 mins of running and will not start again for a few hours. when it dies its like i turned the key, it dosent hesitate at all it just stops. anyone have some suggestions??
Old 04-19-2009, 04:29 PM
2001NBMZ28's Avatar
Have you already tried flashing the light for codes?
Old 04-20-2009, 09:37 AM
ihaterice's Avatar
i have not, isn't there a way to read them with a jumper or a paper clip?
Old 04-20-2009, 09:50 AM
2001NBMZ28's Avatar
Yep. http://shbox.com/1/dlc2.jpg
Old 04-20-2009, 09:59 AM
ihaterice's Avatar
cool, ill pull the codes today and see if that's any help. will i show a code for a water pump temp sensor?
Old 04-20-2009, 10:05 AM
2001NBMZ28's Avatar
Don't think so, but there are codes for the ECT sensor.
Old 04-20-2009, 10:09 AM
ihaterice's Avatar
cool ill check it out and see what i get...
Old 04-20-2009, 04:14 PM
WS6Power's Avatar
Crankshaft Position Sensor going bad.
Old 04-20-2009, 06:51 PM
ihaterice's Avatar
pulled no codes, crankshaft position sensor? any ways to test this, because i am gettin tired of throwing parts at the car.... just would like to test it before i buy a new one if i can
Old 04-20-2009, 07:24 PM
ihaterice's Avatar
i have heard that lt1's prior to 96 did not have a cps... also once in a while when i try to start my car back up after it dies the tach will do some wierd things like jump up to 2000 and then go back down... if that helps any
Old 04-20-2009, 07:48 PM
edcmat-l1's Avatar
Pre 96s don't have CKP sensors. Even if it was a 96+, the CKP sensor is only used for misfire info. You can unplug them and the car will still run.
Sounds like yours is either an opti going bad, or a bad connection somewhere.
Old 04-20-2009, 07:57 PM
98Camarod's Avatar
Whats up with the jet tuning? Does that connect on top of the computer inside the engine bay? That is exposed to the elements, I'd take a look there if that is the case.
Sounds like an electrical problem either way though.
Old 04-20-2009, 07:58 PM
ihaterice's Avatar
alright, i know it has to have something to do with going into closed loop. it is fine when its cold and when it warms up, even if its just from the sun it will die... i cant figure out what would be doing this.... what would shut off the engine in closed loop if it was going bad?
Old 04-20-2009, 07:59 PM
ihaterice's Avatar
the jet tune is a piggyback, but it is off of the car now
Old 04-20-2009, 08:04 PM
98Camarod's Avatar
If the coolant temp is too high, fuel is cut off. Possibly bad ECT sensor? I'm not really sure how those work when they go bad. Maybe someone can shed some light on that. :cough: Ed :Cough:
Old 04-20-2009, 08:07 PM
ihaterice's Avatar
i can smell raw fuel when i try to start it again... but then again i have no cats so i could just smell whats still in the cylinder/ exhaust??
Old 04-20-2009, 08:10 PM
edcmat-l1's Avatar
When it doesn't start, you need to check for injector pulse with a 'noid light, and check for spark. My guess is you don't have spark for some reason. Why? It's too hard to say. Can't really diagnose stuff over the internet. Especially with no real information.
Old 04-20-2009, 08:14 PM
ihaterice's Avatar
does the tach jumping at random times with the key just on lead to anything else?
Old 04-20-2009, 08:19 PM
98Camarod's Avatar
Bad ground will do that.
