2000 ws6 cam swap
2000 ws6 cam swap
hey i need a little help im doin a cam swap in my 2000 ws6 6 speed and i was wondering what is all required to do a cam swap, i know hardned push rods. I already have ls6 heads on it so the springs should be good up to 600 lift. What else do i need for sure anyone help.
What kind of springs are on the ls6 heads?
cam, push rods, oil pump, oil pump O ring, timing chain, crank bolt, motor oil, oil filter, coolant, and pen magnets or the thunderracing.com lifter holding tool.
You might need water pump gaskets, front cover gasket, and front cover O ring.
Since you are going to be in their get ls6/melling oil pump and ls2 timing chain.I would go for better springs if it was me.(DUALS)
____________________________________
2000 t/a ws6 with lots of mods
