FAST Intake questions
Old 04-23-2009, 08:15 PM
LS12Fast4U's Avatar
Question FAST Intake questions
Does the FAST intake have EGR on it or not? Im trying to figure that out before i get one. I will have to get my EGR and AIR deleted if it doesnt. Also do i have to cut my cowl for it to fit or is that only on the vette?
Old 04-23-2009, 08:17 PM
fatdave's Avatar
No it does not come with it, but you can drill it out and still use the EGR.
Old 04-23-2009, 08:19 PM
primer84z's Avatar
assuming your putting it on a F-body, no you dont have to cut the cowl or anything. And like he said, there is a spot to install the egr tube but you have to cut it out yourself.
Old 04-23-2009, 08:21 PM
LS12Fast4U's Avatar
Will drilling it out cause any problems?
Old 04-23-2009, 08:22 PM
LS12Fast4U's Avatar
Cool yea i read an article where they had to cut the cowl but that was on a vette. I didnt know if that applied to f bodys or not.
Old 04-23-2009, 08:23 PM
primer84z's Avatar
no. why do you want to use EGR so bad?
Old 04-23-2009, 08:33 PM
LS12Fast4U's Avatar
I dont want to use EGR or AIR but i dont know how to take it off with my diablo sport. I would like to eliminate them all together.
Old 04-23-2009, 08:44 PM
primer84z's Avatar
any tuning shop can do that for probably 50 bucks. as for the AIR, you dont need to tune that out if you leave the pump hooked up, just unhook all the hoses. The pump will turn on for a while when you first start the car but you wont get a SES light.
Old 04-23-2009, 08:48 PM
LS12Fast4U's Avatar
You have to find a shop that is willing to tune it without the EGR though.
Old 04-23-2009, 08:52 PM
Dewman's Avatar
there is a spot that was ment to be removed if you want to run with EGR and the hardware that comes with the FAST has a self tapping screw to hold it down.
