what trans for H/C/I car?? mm6 or mn12?
like the title says....
rite now i have the MN12 and have gone as fast as 127.85 w/ 4.10s and a
26" tire
should i stay w/ the mn12 and get it built or should i go back to the fbody/viper ratios and get it built
i will be doing a face plated trans
car will be low 10s when im h/c
if i go back to the fbody ratios then ill have to go w/ 4.56s
thanks
brandon
26" tire
thanks
brandon
OP - is the 4th gear the same (1:1) in both? Sorry for the n00b question.
If it was me, I wouldn't get hung up on the small details, i.e. ratio of 1-3.
I agree that a 28" tire and a 4.56 seems to be the setup for a M6 looking for all out 1/4 mile.
However, I'm running a 4.30 and a 26" tire for now... I didn't want to grind my caliper, so I went with a 16" wheel and a 26x11.50x16 M&H Racemaster...
By the way, if you're not running the M&H you need to start now. They make THE tire for our M6 cars man... hands down.
Good luck man.
Good luck man.
