Rebuild Vs New
Rebuild Vs New
my ls1 is sitting around 101k miles and now I'm starting to think about rebuilding the engine or buying a bigger motor like ls2 or ls3. I know 101k is not bad but it will take me bit time to save up enough money to do either. (married w/2 kids in the military) I just want to see what people's opinion is about the two. I kind of want to stick with the ls1 but i don't know how reliable it would be after a rebuild because I've seen rebuilt engines take a **** with low mileage.
LOL, with a proper rebuild it will last a long time but the question is will you be happy with the same power level after spending the money?
A bigger engine will cost a little more but also give you more power so it's something to think about. You can go to a 383 with your current LS1 during a re-build and get more cubes for less money than going to an LS2 or LS3.
^^ Agreed but not for cheaper than using the block he already has. I mean if he can find a 6.0 at the junkyard for $100 then go for it !!! But if he is not looking to make 600 rwhp then a 383 is a good way to get more power and save some coin as he already has a block to use.
going to 383 sounds like a good idea...nothing is wrong with my motor as of now. well see once i rebuild the motor i would feel a lot safer using forced induction...that was pretty much the plan if i was to rebuild the motor.
This guy has what you need and you have what he needs.Maybe you could help him out.I've always thought it a shame to pull apart a good running motor.
https://ls1tech.com/forums/lsx-parts...ort-block.html
