head and cam
Old 04-24-2009, 09:24 PM
lt1formula275's Avatar
Default head and cam
whats a good head and cam combo its a 95 formula auto it will have a stall dont want to rev it past 6100 unless its safe to do so have about 4000 dollars to work with but some of tht will go to engine rebuild and basic bolt ons like headers and such all the work will be free so all the money is just the cost of parts labor is not an issue
Old 04-24-2009, 09:25 PM
SpeedDensityZ's Avatar
AI (Advanced Induction) Heads and Cam. Numbers in sig.
Old 04-24-2009, 09:37 PM
FbodyFreak's Avatar
+1 ai is good stuff
Old 04-24-2009, 11:06 PM
JAKEJR's Avatar
A "good head and cam combo" will depend on your intended use of the car. What would be "good" for a daily driver probably won't be for a race car.
The cubic inch displacement is a big factor too. So I suggest you sit down and come up with a plan, a plan for how you intend to use the car and what your goals are.
Jake
West Point ROCKS!
Old 04-24-2009, 11:38 PM
za355tx's Avatar
Lloyd Elliott is the other place to look into doing heads and a cam.
www.elliottsportworks.com
Advanced induction is very good as well.
Old 04-25-2009, 12:36 AM
SoxXpupPeT's Avatar
both lloyd and ai will give you a great product for your dollar. i went with LE's cam but AI's 200cc heads sound quite yummy
Old 04-25-2009, 08:21 AM
96capricemgr's Avatar
Jake
West Point ROCKS!
Except that the AI ported stockers have proven time and again to be great for everything from a 350ci daily driver too capable of 9 second NA 383ci car. Granted if aiming for 9s NA I think their Trickflows are a better choice but there are VERY few cars doing that and I think it very clear that is not where thos poster is heading.
http://advancedinduction.com
Old 04-25-2009, 09:41 AM
it will be daily driven and at my track lt1s dont run as good as other places they run high 14's all day my fastest is a 14.8 and with heads and cam i want it to be in the 12's emmissions are not a problem i mean i want a beefed up street car tht i can take to the track if i want and whip stock and lightly modded ls1's I want it to have between 375 and 425 RWHP Yall just give me yalls opinion on it
Old 04-25-2009, 09:53 AM
By the time you are done with the rest of the valvetrain and gaskets and all you can pretty much plan on spending $3000 on a topend. I know that sounds like a lot after looking at a website and seeing $15-2000 but like I said the rest of the valvetrain and gaskets and such add up. If you spend less fine but do not PLAN on spending less or you could put yourself in a tight spot.
Old 04-25-2009, 10:10 AM
If you're looking for driveability more cubic inches is better. My car drives great and with the bugs worked out of the tune and the cutout open I expect between 460-470whp on a car that could be daily driven if need be.
Old 04-25-2009, 10:14 AM
With a $4000budget he can not even begin to consider adding displacement though.
Old 04-25-2009, 10:30 AM
Forgot about the budget.
ur right i cant be adding displacement it will be a stock bottem end lt1 if i didnt mention tht
Old 04-25-2009, 10:36 AM
yea thts why im working a plan out right now before i start buying stuff and the budget will go higher over time i dont mind waiting a little while for it to be done right
Old 04-25-2009, 10:55 AM
if i got the money i like AI heads the 190cc heads are probably good enough is any work required to the bottem end to use the heads like i dont have to change the pistons do i
Old 04-25-2009, 10:57 AM
James Montigny's Avatar
Exactly, put the money into a good H/C/I combo with quality supporting components and a good tune.
You'll eat up most of the budget and have a little left for a few bolt-ons or
to get a head-start on the savings for the next round of mods.
I've said it before and I'll say it again.
H/C is a gateway drug.
Yes, you can run an H/C combo on a stock bottom end as long as it holds compression (IE: leak-down test)
Keep cam duration below 230/236 and RPM under 6500 if you want it to perform and last.
Overcamming is extremely common for first timers. (an expensive lesson to learn the hard way)
Both LE and AI provide an excellent selection of cams to match the portwork and application.
Old 04-25-2009, 11:06 AM
def not pushing it over 6500 and thanks i like AI 190cc heads what u think
Old 04-25-2009, 11:11 AM
I think you'll be very happy with the 190cc combo.
Old 04-25-2009, 11:35 AM
alright what cam do u suggest going with AI 190cc heads its gone be a dd i want around 375 to 400 RWHP if i can get it i will have more mods then just H/C if i got the money ill have the intake ported as well
Old 04-25-2009, 11:43 AM
One question on the AI website it talks about a core charge does tht mean if i send them my old heads i dont have to pay the 600 dollars
Quick Reply: head and cam
