Junkyard 10 bolt-good idea?
I have the 2.73 gears and am sick of the slowness. I dont know of any local shops that are reasonable for installing gears.
Is it worth it to pull out a junkyard rear end with 3.42s? I would guess a junkyard rear would need new seals all around, and I would probably like to have new bolts to use to attach it.
I dont really want to spend $2000 for an axle right now. maybe it would be better to have my gears swapped out by a shop, rather than swapping in a junk rear.
Only thing to worry about is that a 3.42 rear would certainly have come from an M6 car, which means it's likely to have a shorter life expectancy than say a 3.23 rear out of an A4 car. Although going from 2.73s to 3.23s isn't exactly worth the hassle of buying and swapping rear ends...
I did exactly what your thinking of doing except my rear was completely shot. So we picked up a junk yard 3:42 rear end ,and i couldn't be happier. For 500$ it has new seals and all and was installed for that price I'd say go for it.
this way you in a 9" for 12-1300, will be a lot strong than a rebuilt 10 bolt
later if you want you may buy a mose or strange center and then buy an adjustable TA
try BOB at Brute Speed
just my .02'
Johnny
you will also need to buy the torque arm bracket from moser,which mounts to the axle housing.you can use your stock torque arm and beef it up with extra tubing.talk to BOB at Brutespeed for better infor.
